2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum 2011 535i Transmission Jerk?
      08-19-2016, 11:12 PM   #1
izaazk
Drives: 2013 335i
I bought a 2011 535i non-sport from my local Motor Werks dealer recently...
ever since i bought it it has a slight rough idle almost like a mis fire but not really a mis fire... no CEL or anything....
When the transmission shifts... its slow, choppy, and very jerky going up and down the gears...
any input? software update? trans fluid change??
Any help would be appreciated!
Gets slightly better once the car is fully warmed up!
      08-20-2016, 12:23 PM   #2
Bmw doubles
Dream crusher
Bmw doubles's Avatar
Drives: Fast
2011 535  [0.00]
Not sure if there's the Alpina TCU flash for F10's AT. If so definitely have it flashed, but could be a separate problem your having. See if the dealer has a recall. I have a MT so for me it's the clutch delay valve that is a POS.
IG: @bmwdoubles
      08-20-2016, 11:09 PM   #3
izaazk
Drives: 2013 335i
I will check my local Motor Werks dealer soon....
Its weird like I can feel EVERY up shift and DOWN SHIFT... its terrible when its cold but gets smoother over time when it warms up but still feel them
      08-20-2016, 11:33 PM   #4
Bmw doubles
Dream crusher
Drives: Fast
2011 535  [0.00]
Just had my car coded today and asked my guy who does coding about your transmission. He said there is no Alpina TCU flash for F10's, but there is a software update from the dealer that might address your problem. Keep us posted.
IG: @bmwdoubles
      08-21-2016, 10:31 AM   #5
claykin
Drives: various BMW
Definitely ask dealer to update your Istep level to current. Or at very least check service history and current Istep to make sure it's reasonably current. Also check to make sure all services have been completed.
2023 840GC | 2021 740i | 2019 X3
      08-22-2016, 04:01 PM   #6
izaazk
Drives: 2013 335i
I will ask if they can do a software update...
would it also fix my rough idle? like it feels like a misfire but it isn't one... NO CEL..
Apparently the service history said plugs were changed before I bought the car.. I don't know what else could be the issue..
every cold start as the revs come down it shakes like a mis fire.... also when letting the brake pedal go off a red light you also feel the same vibration
would a jb4 help me fix these problems?
      08-22-2016, 04:23 PM   #7
lsturbointeg
lsturbointeg's Avatar
Drives: 2011 535i Jet Black
i would bring that to the dealer's attention and let them know the issues you're having so they can take care of it. keep us posted on what they decide to do and if it fixes what you're experiencing
      08-22-2016, 05:29 PM   #8
izaazk
Drives: 2013 335i
I will definetly ask them sometime soon... only problem is I am out of warranty so hopefully they honor as a courtesy since its been less then 1 month since i bought the car and its been doing that since day 1
      08-22-2016, 05:31 PM   #9
lsturbointeg
wait...no warranty and you just bought the car
      08-22-2016, 05:56 PM   #10
izaazk
Drives: 2013 335i
I bought it pre owned lol 76K miles :/ GREAT deal though
      08-22-2016, 09:19 PM   #11
AmooManiak
Drives: 21 X5 M50i -> M2C -> 21 M5C
I had a simliar issue in my E60 545i. The 1-2 shift was HORRIBLE! It usually happened for the first 5-10 minutes and only in colder weather.
The E60s had known issues with the Mechatronics unit, which also caused it to leak oil. My short term solution was to get a transmission oil change/add oil. First thing I would check is your oil level.
      08-22-2016, 09:55 PM   #12
Bmw doubles
Dream crusher
Drives: Fast
2011 535  [0.00]
Rough idle could be dirty maf
IG: @bmwdoubles
      08-23-2016, 12:08 PM   #13
izaazk
Drives: 2013 335i
is the MAF on the charge pipe?
I was thinking of taking time out to replace all the plugs just to get that out of the way since its cheap and easy!
      08-23-2016, 02:34 PM   #14
Bmw doubles
Dream crusher
Drives: Fast
2011 535  [0.00]
On the back of the air filter
IG: @bmwdoubles
      04-29-2019, 06:24 PM   #15
BMDubbya535
BMDubbya535's Avatar
Drives: BMW F10 535i xDrive, e90 335d
It was my faulty Auto-Hold without it registering an error
Same symptoms and I thought this would be the end of my wallet until I got an e brake malfunction that actually made me run like new
      04-30-2019, 01:24 PM   #16
HizEternal
Drives: Jet Black F10 535XI
I have the same year but with xdrive and have gone through the trials and tribulations lol. Check your ignition coils and make sure they are operating correctly, if not replace all 6 with the Bosch ones. The coils or one of them sometimes go bad and it’s better to replace them all. Also make sure there’s no vacuum leaks. The easiest one to do is take it on the highway and punch it hard, if you do get a drive train malfunction while doing that, then one of the injectors May be clogged.
That’s the engine side, the transmission is a moody beast. A software update may fix it and mine behaves like yours (I never did the update). I changed my fluid at 70k so I know it’s not that. But I do see that if it’s 60f outside it’s silky smooth but any higher or lower it’s either hanging on cold drives till warm or hard shifting after long drives while hot.
      04-30-2019, 03:34 PM   #17
Surly73
I thought Delphi was now the recommended best coil for N55 (and Eldor for N54)?
      04-17-2024, 07:52 PM   #18
BMDubbya535
Hey guys just wanted to say that a rear diff fluid refresh will fix this. At least it did for me.
      04-18-2024, 09:42 AM   #19
wesamjaber2004@gmail.com
wesamjaber2004@gmail.com's Avatar
Drives: Bmw 535i
I would do a full service of front differential, rear differential, transfer case (remember to do Guibo too since the exhaust comes off) and even transmission service since you’re at the exact mile service mark to do it too. I’d do that for sure asap before it’s too late and the fluid goes black. My transmission is tuned so tbh it jerks sometimes on takeoff with first gear but I think it’s fine still. As far as your rough idle, I had this similar issue, definitely ask for a smoke test of even do one yourself if you can. Put smoke through the intake pipe to see if any leaks are present. Leaks leaks leaks will cause rough idles. But if you wanna start off, maybe just do spark plugs, coils, and clean the maf sensor which is very easy to do as a diy. These cars are extremely sensitive so definitely check for a leak. I’d also check the pulleys and belt tensioner especially the harmonic balancer/crank pulley as these are very common to wobble and cause vibration. Everything I said by the way I’ve fixed on my car and it’s vibration free for the most part. On cold start I know what you feel as I feel it but it’s not bad tbh, it could be a leaky injector which is very common to cause rough idle on cold start. Also there is plenty of threads on the rough idle we experience on the f10 535, it’s very common. Take in account of everything I said as I went through everything you have already and got my car to solid condition so I’d definitely take this all into consideration when diagnosing. Let me know what it comes out to be!!
      04-18-2024, 10:53 AM   #20
ChiNorm
Drives: '13 535xi
"Gets slightly better once the car is fully warmed up!"
Has the transmission fluid been changed or is it the original?
