09-17-2020, 02:14 PM | #199 |
Rep 79
just got it installed. Mid-cornering is more flat, and precise. Braking is also a bit more consistent if dive a bit deeper. Everything on the suspension is stock.
10-15-2020, 02:34 PM | #200 |
Rep 441
Just sending out some gratitude to you guys - great thread - ordered mine, got all the install tips and torque specs I'll need from you all
2013 535xi M Sport (PWG) // PS2 // Spool fx150 // MHD // xHP // FTP Inlet // FBO: AR HF DP, Wagner IC, BMS Intake, VRSF CP
ramman434712.00 lsturbointeg9158.50 |
10-16-2020, 12:09 PM | #201 |
Rep 538
As long as you have the right bits, it's a quick install. I had to pull the bar itself (mounts stayed on) a month ago to change my spark plugs. Had it completely off in under a minute, and same to remount. Super easy
'07 Montego Blue/Saddle Brown E92 335i - 6spd. - SOLD
'16 Carbon Black Metallic F10 535i M-Sport - TOTALED 11/21/21 '13 Black Sapphire Metallic F30 335i M-Sport - unknown charge pipe, MSport Exhaust, 20" 405M wheels, $61k MSRP, CF M4 Mirror caps & Spoiler, NGK plugs, Dinan Coils, BMS intake |
burro_blasta131.50 |
10-19-2020, 06:18 PM | #202 |
Rep 423
My EBay strut bar just got delivered.
Checkout my YouTube channel, Like and Subscribe. https://www.youtube.com/user/Gjohnson7771 MHD Flash, RVG Catless DP, RVG CP, RVG Boost Pipe, Walbro 455 LPFP, Style 433 Wheels, BC Coilovers, Ebay Strut bar, M-Sport Front Conversion, RVG FMIC, 6WB Cluster. |
lsturbointeg9158.50 ezaircon4jc4492.50 |
10-19-2020, 08:02 PM | #203 |
Rep 423
Install was cake.
10-19-2020, 08:05 PM | #204 |
Rep 14,521
dude, you need to wash and detail that engine bay!!!
ramman434712.00 |
10-19-2020, 08:18 PM | #205 |
Rep 423
Lol! I was thinking the same thing!!!!!!!!
10-25-2020, 08:08 PM | #206 |
Rep 1,442
Drives: 2011 535i 6MT
Ha, have fun adjusting your BC coil overs now... we are in the same boat
10-25-2020, 10:03 PM | #207 | |
Rep 423
Oh, cleaned up the engine bay. Still need to paint my strut bar and other bars.
10-25-2020, 11:07 PM | #208 |
Rep 2,591
For those who want to still adjust their coilovers: if your brand offers the remote adjuster stick things, just drill a hole into the mounting base and stick it through. I'm about to test this myself lol
2015 BMW 535xi
10-26-2020, 12:23 PM | #209 |
Rep 423
Let me know how this works. Although, I don't plan to adjust my coils often.
10-26-2020, 12:31 PM | #210 |
Rep 1,442
How would that work? I would guess the base plate wouldn't allow you to access it, but maybe I need to go check it out... I'd be very interested in this mod.
10-27-2020, 03:54 PM | #211 | |
Rep 2,591
https://www.fcpeuro.com/products/br-...dium=ppc&ttv=2 Basically, it replaces the original knob, and is a flexible metal rod. You'd thread that through the hole you drill in the base plate, and can then rotate it. Works on the same principle as those flexible screwdriver attachments. They might look too long, but that's because they're intended to be cut to length. Take top knob off, cut it, then reattach top knob to the shortened wire.
2015 BMW 535xi
10-27-2020, 11:32 PM | #212 |
Rep 1,442
Seriously? More toys!? Fun never ends with this stuff...
10-30-2020, 08:15 PM | #213 |
Rep 441
Install was extremely straightforward - unlike BrowBMW, who has a full Kardashian season's worth of strut bar drama :
Huge sigh of relief when all my mount bolt holes lined up. A few things to add: - the hex on my bolts isn't 1/4", it's a bit larger and actually 7mm. It takes enough force to do the initial clamping of the bar mount that I figure the 1/4" hex would've left me brokenhearted with a stripped bolt head. Reminder that the other nuts are 17mm (two need socket and two need wrench). 28nm on the 6 strut tower bolts and 24nm on the two bar mounts indeed felt reasonable - like BrowBMW I have the BMS intake. Like him, I removed the vertical torx screw to allow the filter and tube to shift forward 1/2-1" (towards the bumper) so the strut bar had clearance. Before that I took off the intake in order to move the intake clamp screw to the underside so it didn't bump against the bar. Unlike BrowBMW, after the bar was bolted down I was able to push the filter/tube back into place and line up/screw in the torx screw without issue. Maybe I'll have some issues after some driving, dunno. Pics attached - my bar is a bit scratched up, and I figure this is some kind of "factory seconds" situation where the seller got the hook up and is unloading stuff that's not suitable for the showroom. Whatever, as you can tell from my engine bay I'm not planning on showing off anytime soon
11-02-2020, 07:47 AM | #214 |
Rep 1,442
Nice! Just paint the bar anyway and you'll be good to go! Drama... wait til you see the diverter valve video - It went from a DIY to a bloopers video.
11-02-2020, 03:16 PM | #215 |
Rep 538
Mine was scratched up too. I posted pics a couple pages back. Eventually I'll just paint it.
11-18-2020, 08:26 PM | #216 |
Rep 423
Got my Strut bar installed. Everything lined up perfectly. Now I just need to pull it back off with the other braces and lay down some paint.
BMW F10 Mods: Ebay Strut bar install
12-16-2020, 12:07 PM | #217 |
Rep 639
Just ordered mine today on eBay. $45 plus $39.78 shipping. Should arrive sometime in January or February. Looking forward to installing it and replacing a few more parts of the suspension when I eventually have time.
