2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications n63tu turbos vs alpina turbos on n63
      03-30-2018, 11:46 AM   #1
byebyev8
Drives: e92 335i f12 m6
Which turbo's perform better? seems like the n63tu turbos flow well enough for 600whp.
      03-30-2018, 12:18 PM   #2
warpeacelove
Drives: 550i
N63TU differences
Engine mechanical
• New cylinder head due to use of the Turbo Valvetronic Direct Injection (TVDI) procedure
• 3rd generation Valvetronic
• New valvetrain with modified timing
• Adoption of VANOS from the N55 engine
• New cylinder head cover with adapted crankcase ventilation
• Pistons with modified piston crown geometry
• New connecting rod with even pitch and adaptation of the crankcase due to modified connecting rod shape
• Adapted crankshaft
• Chain drive with modified guide rails and an extruded chain with 142 elements.
Oil supply
• Pendulum slide cell pump with small overall width
• Eight individual oil spray nozzles for piston crown cooling.
Cooling
• Integration of the two engine control units in the low-temperature circuit and cooling over the back panel with cooling pipe
• Expansion tank under the left side wall with separate filling hopper.
Intake and exhaust emission systems
• Adaptation of the manifold for the air intake duct due to new geometry of the cylinder head cover
• Use of the hot film air mass meter 7
• Adoption of the charge air temperature and intake-manifold pressure sensor from the N20 engine
• Exhaust turbocharger with new compressor and modified wastegate valves
• Discontinuation of the blow-off valves.
Vacuum system
• Two-stage vacuum pump with new arrangement of the bolt connection
• Vacuum reservoir for the wastegate valves in the V-area of the engine.
Fuel preparation
• Use of the known high-pressure injection with injectors and high pressure pump HDP5
• Discontinuation of fuel low-pressure sensor
Engine management system
• New dual control unit concept with one control unit per bank
• Oil level sensor with an additional temperature sensor in the main oil duct behind the starter motor.
      03-30-2018, 12:19 PM   #3
warpeacelove
Drives: 550i
Turbos aren't the same.
      03-30-2018, 06:03 PM   #4
747flyboy
Drives: 2008 M3 2012 550i M
compare part numbers and schematics on realoem.com
      03-31-2018, 12:32 PM   #5
addy27
Drives: F10 550i
Not having diverted valves makes n63tu not applicable for N63. However, the Alpina Turbos all have diverted/blowoff valves. The older Alpina Turbos based on the n63 platform should be a direct swap.
      04-03-2018, 10:52 PM   #6
535_BiTurbo
Drives: 2012 550I - BMS Stg 1 & CAI
Are the turbos the same?
      04-04-2018, 07:26 AM   #7
badblack550xi
badblack550xi's Avatar
Alpina turbos are not the same they are way better
2011 550i RWD 60-130 7.35
      04-04-2018, 08:41 AM   #8
warpeacelove
Drives: 550i
from where and what model year etc?
      04-04-2018, 04:57 PM   #9
535_BiTurbo
That's what I was thinking too
      04-04-2018, 05:01 PM   #10
byebyev8
I just figured since bms dynoed 600whp with the n63tu turbo's and the highest dyno ive seen from the alpina's was around 570whp. I do realize the n63tu has alot of other upgrades over the n63 that also contributed to the 600whp dyno.
      04-05-2018, 11:56 PM   #11
535_BiTurbo
N63 is tuning limited
