2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications MHD stage 1 on a stock 535i - Impressions
      05-02-2018, 08:05 AM   #23
etnsandman
Drives: 2015 M5 Competition
Not sure about the beta status. If you message MHD of Facebook they'll answer you.
As far as my flash choice check out this excerpt from the handbook.
Q: I don’t have a FMIC installed on my car yet, is it safe to run one of the FMIC maps and is it safe.
A: Yes, you can run one of the FMIC OTS maps, but it is recommended that you datalog, and ensure the car is not knocking, and the IATs and fueling remain healthy. We advise against using Step up MAP on cars without the recommended parts if using for track days and sustained aggressive driving. USE AT YOUR OWN RISK, MHD is not responsible for any damage done to your car using MAPs intended for modified vehicles without the recommended upgrades.
So, I spend the majority of my time babying my 535i commuting. So I went for the 2 map for the occasional burst of fun. I am 47 and have self control, if your still driving like Ken Block everywhere you go then you better keep it conservative until you get that fmic and meth.
      05-02-2018, 07:59 PM   #24
SC300T
Drives: 13 E92 M3, 540xi, 535ix GT
Tonight I flashed the MHD stage 1 E30 map (included in the ethanol map pack) and put in 5 gallons of E85 to 9 gallons of 92. I had also changed plugs last night to the NGK 95770 gapped to .020. On a stock PWG N55, there doesn't seem to be much advantage. Logs look fairly clean, boost 14ish mid, 10psi up top with perhaps a bit more timing. IAT around 104 so today was hotter. Maybe it doesn't feel quite as good as the initial 93 stage 1 flash because of the higher air temps today (83f).
I just don't think there is much advantage on a tiny PWG that can't generate enough boost up top. On my E90 N54, an E30 mix would generate substantial gains - this one is sort of meh...
Theoretical question: Assuming equal timing and boost on a given car, will an E30 mix make more or less power than 93? I'm assuming it will make a little less...
      05-03-2018, 04:41 PM   #25
ssgm1x
ssgm1x's Avatar
Drives: 2020 M340i & 2018 M3
Originally Posted by dmorris30 View Post
I would like someone to review my data log. I am concerned with all the timing corrections i'm getting once i get high in the rpms. Mods are vrsf chargepipe, vrsf downnpipe, and bms intake. MHD stage 2 tune on 91 octane.
https://datazap.me/u/megadsmgmailcom...og=0&data=4-20
I see a lot of throttle closures.
2020 BMW M340ix Dravit Grey
2018 BMW M3 Alpine White
      05-03-2018, 04:49 PM   #26
ssgm1x
ssgm1x's Avatar
Originally Posted by etnsandman View Post
Well I have some 0-60 numbers for my car. But first I need to state that the Bridgestone Serenity Plus tires are really lacking in the traction department.
Pre-flash the best I could muster was 6.7 0-60, MHD got it to 5.6, but traction sucks. Still, with better tires I think it would be even faster. Need to get the car lower so the staggered 19's that have Pilot Sport A/S3+ tires on them. Way better traction for sure.
and what model car/engine type ? just curious , thanks a bunch !!!!
      05-04-2018, 10:26 AM   #27
TXWatchGuy
Habitual Line-Stepper
TXWatchGuy's Avatar
Greece
Drives: 2010 335i Coupe
I bought and installed MHD last night with the monitoring pack. The Play store wouldnt let me purchase the OTS maps. Lol. So I'm driving around with an untuned tuner. Pffff.... FML
      05-04-2018, 01:32 PM   #28
SC300T
My Amex company sent me a fraud text message after the first purchase that I cleared up with them via text. I think it sees online purchases together and triggers a fraud response. I'd check with the CC company and while you are on the phone with them they can make sure the transaction goes thru.
      05-06-2018, 02:44 AM   #29
TXWatchGuy
TXWatchGuy's Avatar
Greece
I was actually busy the last few days so just got around to finishing the install today. Bought the stage 1 ots map pack without any problem and installed the 93 octane tune. I have to say I'm impressed. Makes the car feel like it's got some balls now, especially once in 3rd gear. (6MT) I know it's never going to feel as quick as my old N54 335 with JB4, but it definitely feels like it can get out of its own way now.
I think next mod will be a dp and a custom tune and will leave it at that. I need to quit modifying cars till they're undriveable. Lol
      05-06-2018, 03:20 PM   #30
harris69
Drives: 1997 M3/4, 1984 533i,1997 328i
Any chance you could do a 0-60 mph run?
      05-07-2018, 06:00 PM   #31
harris69
So finally installed the OTS Stage 1 (took 30 minutes to install), and car feels fast as shit. Did a few logs, and since I have no idea on how to read them, I would like someone to decipher them for me.
      05-07-2018, 08:25 PM   #32
ey2001
ey2001's Avatar
310
Drives: F10 535i 6spd
You should upload the file... im sure ssgm1x will help you out..
F10N557.00
      05-07-2018, 09:58 PM   #33
harris69
https://datazap.me/u/harris69/log-15...og=0&data=3-12
      05-07-2018, 10:19 PM   #34
TXWatchGuy
TXWatchGuy's Avatar
Greece
I don't have a vbox or anything. I haven't played with the software enough yet, is there a way to do it on there? Can i run a log of time vs speed or something?
      05-22-2018, 08:21 AM   #35
SC300T
I've been running the stage 1 E30 map for a little while now... About 5 gallons of E85 with 9 gallons of 92 premium unleaded. Seems that the ECU is adapting a little and the car seems to be running stronger, even with some higher ambient temps in the area. It's now a good deal more responsive and powerful than the 93 map. The longer I'm running it, the stronger it is getting. With the 93 map there wasn't much variability. The jump isn't as significant as going from stock map to stage 1 93, but it is a very noticeable bump and recommended if you have access to E85 (and you don't mind going contrary to BMW's ethanol recommendations). I have the NGK 95770 plugs gapped to .020".
      05-22-2018, 01:15 PM   #36
ssgm1x
ssgm1x's Avatar
These 3 datalogs are no good because you are only giving it 50-75% throttle......do a proper log and then post it if u can. Thanks !!!
      05-23-2018, 07:11 AM   #37
harris69
Took one yesterday on 91-95 octane tune with 93 octane in the tank. My IATs are out of wack and accordingly to MHD I need an aftermarket FMIC. Does anyone else have this issue? During normal cruising my IAT was 99 F, but shot up to 122 F once I goosed it.
https://datazap.me/u/harris69/may229...og=0&data=3-14
This was my second datalog after switching to it from 93-98 octane tune.
      06-11-2018, 08:23 AM   #38
equ
Drives: Croc & toaster
Just did the MHD Stage 1 on an otherwise stock 2011 535i 6-speed. Very smooth and the butt dyno says the car is more awake, feels closer or even with a 2011 335i (e90). Process went smoothly, plugged car into charger, used bimmergeeks pro cable, followed instructions. I also got some fraud messages, but you can use two cc's or you can paypal.
      06-11-2018, 12:23 PM   #39
harris69
Post your logs bruv.
      06-14-2018, 08:06 AM   #40
etnsandman
Hello all. Still rocking Stage 2 on my fairly stock 535i and love it. Getting 24mpg in mixed driving and is so much fun when I give it the beans. I did have one super knock incident, but a fresh set of spark plugs and all is good. After the super knock i went done to the 91 octane tune until I could change the plugs.
MHD is great.
      06-14-2018, 12:07 PM   #41
harris69
I am still getting timing pull. What do you guys suggest?
https://datazap.me/u/harris69/june14...28-29-30-31-32
      06-14-2018, 02:51 PM   #42
SC300T
Move to Alaska.
Not hitting any torque limiters, not pulling timing on any one cylinder. Do you have fresh spark plugs? Maybe find some better gasoline and/or mix with E85.
Good log, by the way - hammer down in 4th all the way up to almost 7k rpm.
      06-15-2018, 01:35 AM   #43
harris69
Moving to Alaska is not an option 😀 . Got brand plugs but not sure on the gap as my mechanic put them in. Also running a 91 tune with 93 octane in the tank.
I plan on checking the gap and waiting on VRSF to release their intercooler. In the meantime stock intercooler it is.
      06-15-2018, 08:22 AM   #44
SC300T
Perhaps wait until morning to get a pull in a 65 degrees? Could just be heat. If your car is 100%, I would not expect any timing pulls at 65-70 degrees ambient temp WITH GOOD QUALITY GASOLINE. For giggles, I'd switch brands of fuel.
