2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications N63 engine replacement question?
      11-07-2018, 05:02 PM   #1
brogers710
brogers710's Avatar
Drives: 2008 BMW 328I & 2011 550i M-Sp
Has anyone had their N63 engine replaced yet related to the class action suit? If so can you elaborate on cost and how the car is running since the replacement? Oil consumption?
      11-07-2018, 05:13 PM   #2
budmun
Drives: BMW f10 550
There is a recall for the motors in which dealer will replace?
I recently installed a new motor in my 550xi. Dealer wanted $5,500 for the installation not including the motor.
- Dealer install $5,500
- New motor from dealer $3,600
- New Turbos from dealer $849
I have been driving with the new motor for about 150 miles - runs like a dream and pulls like a freight train. At the rate I drive it may be a while before its broken in so to speak but so far Im happy.
      11-07-2018, 05:39 PM   #3
brogers710
brogers710's Avatar
Yes the class action lawsuit Bang vs BMW
Anyone with N63 engine can get reimbursed or new engine replacement at various percentage based on mileage. What year and how many miles did your car have prior to replacement?
      11-07-2018, 07:08 PM   #4
brogers710
brogers710's Avatar
No one yet? Engines are on back order already so I'm surprised?
      11-08-2018, 08:01 AM   #5
budmun
Drives: BMW f10 550
2012 550 xdrive - had just over 127,000 when the motor killed itself; Prior owner noted it was burning oil.
      11-09-2018, 06:41 AM   #6
NinetyEight740
NinetyEight740's Avatar
Drives: 2 - 2013 535i msport
2010 E91  [0.00]
Motors are back ordered until atleast January. So you will not find the answer you are looking for quite yet.
      11-24-2018, 12:10 AM   #7
svt1998gt
Drives: 2008 e90 335i, 2012 X5 M spor
Hey guys, whats the process for getting on this list? Anyone in socal worth referring me to?
I have an x5 with 131k n63 and a f10 with 41k miles on it.
      11-24-2018, 09:15 AM   #8
Arnold550i
Drives: 2011 550i
I recently posted about the whole N63 lawsuit and the case with my 550i the first step to getting on this list would be to take it to your dealer let them know about your oil consumption and they will run tests (will take about 2-3 days) to determine wether it's your turbo seals which is cheaper in ways or your valve seals which is why bmw is replacing the engines after that they will let you know what percentage they are willing to cover etc
      12-05-2018, 11:01 PM   #9
Supahone
Supahone's Avatar
Drives: 11 550I, 07 335I,
So if I understand this correctly, if BMW does find that the engine is consuming oil after they run the 2-3 day test, will BMW replace for instance the oil return line cover and turbo seals for free if those are the sources of the leak due to the recent class action suit decision?
      12-06-2018, 10:55 AM   #10
wmg/bmw
wmg/bmw's Avatar
Drives: BMW 550i GT Xdrive
Correct, the warranty is this - on N63 it was 120k its now 131k for N63 engines for the valve seals. If its the valve seals leaking they will repair no charge if under 131k. Mine took 1 month however bmw said because my timing chain guides did not look good not to reinstall the engine they will send a new engine to install, I have 113k on mine soon to be zero....
      12-18-2018, 12:55 AM   #11
2011550xi
Drives: 2011 550xi
I have a similar story... My 550xi is at the dealer for the oil consumption test - right away the advisor knew my vehicle was burning oil and said it’s a waste of time going through this process. A week later I received a call and my car failed the test, and the timing chain was bad. BMW North America told him to replace my engine and I’ll be getting it back in February, or March. I think BMW North America has realized they’re wasting more money paying the dealerships to do patch up work and have it fail again - just to end up replacing the short block anyway.
      12-19-2018, 12:55 AM   #12
svt1998gt
As soon as I saw this post, my engine just hit 132k, FML.
      12-28-2018, 11:06 AM   #13
sison550
Drives: BMW F10 550i 2012 M Sport
does BMW NA make the ultimate decision to replace the engine? I just dropped off my 12' 550i for valve stem seals repair (covered by dealer). My 550 has 60k miles... i am just not sure what qualifies for valve stem seal repairs vs engine replacement.
      12-28-2018, 11:51 AM   #14
Supahone
Supahone's Avatar
In my case it failed the first oil consumption test. When the diagnosis was completed it was determined and approved that the turbos and valve guides were to be replaced. My car was burning about a quart of oil every 500 miles and I was getting that tell tail puff of blue smoke when idling for more then 15mins. My 11 550i had about 93k when I brought it in and other then the oil consumption it ran rather well.
      12-30-2018, 08:40 AM   #15
EZgo
Drives: 2011 550i
      01-03-2019, 02:14 PM   #16
beetle6986
Drives: E90 335xi, E70 X5 50, 04 Cobra
Originally Posted by Kyngofpop View Post
No one knows, my car was running well as well but the only thing they approved was a $12,900 cost to me engine replacement. It's consumption was 1 quart every 500 miles...
My 2013 X5 has a new engine on order under the class action suit. I use a quart about every 700 miles. I complained about the issues when the car had less than 70k miles. They finally agreed it needed an engine once I passed the 80k mark by about 50 miles. Delaying action on their part certainly helped them as now I'm in the 45% bracket by about 50 miles. It failed both the oil consumption test and a compression test.
I have always had american cars my entire life except for one Nissan which had minimal problems. I'm amazed at the issues that come with a BMW.
2008 335xi - JB5 ISO e50, VFSR catless DP, DCI, VFSR FMIC. Fuel it stage 1, VMR V710s. 407/446 rwhp/rwtq.
2004 Cobra - Basic bolt ons with a tune. 450rwhp/rwtq450. Port coming soon.
2013 X5 50i - muffler delete, xHP tune, ESS tune on the way.
2016 Mustang GT Roush Phase 2 with VMP 767 HP kit.
Kyngofpop676.00
      01-07-2019, 01:33 AM   #17
abhaxus
Drives: 2012 550i M Sport
My 2012 550i suffered internal failure with no warning on July 5. Been waiting for a motor ever since. 69k miles. Something came apart internally while I was coasting on the interstate.
Route 66 is covering most of the cost. BMW/Dealer did not offer me anything for transportation until I went to a different dealer and complained, almost 3 months later I finally got a loaner. 4 weeks after that (in mid October) I was asked to bring the loaner back, and BMWNA got me a rental from enterprise.
Dealer SA called me a few days ago and said they still don't have a date. I've asked them dozens of times for a written copy of the estimate they gave me, and never received one.
Wanted a 5 series V8 since I was a teenager. Someone in my parents neighborhood had an Alpine White E39 540i that was always in the driveway - I was in love with that car. Now I'm paying for car insurance and a loan on a BMW while driving a 4cyl Malibu from enterprise. I was hoping BMW would give me my car back for christmas
Kyngofpop676.00
      01-12-2019, 06:56 PM   #18
resmaj1
Drives: 2013 BMW X5 50i
2013 X5 50i
ok...here is my deal.
Bought my 2013 X5 50i in Jan 2017...only 11K miles (paid 35K for 85K MSRP)and as of today I have 51K miles on it. No real issues until recently notices engine oil low between Oil Changes. HEard about the engine issues and brought car to dealership for consumption test. Learned today it failed, and they will replace valve stems...and I have to cover any internal parts estimated 500-1000. So my question is....does this solve my problem? For how long? When and why won't they just replace the engine? Or is that next? Thanks for any help...trying to decide to keep or sell after this fix.
      01-12-2019, 09:04 PM   #19
Supahone
Supahone's Avatar
Depends...
It depends on several factors from what I've read and experienced personally. The miles on the car. The amount of damage the oil leaking has caused. The condition of the turbos and related seals and lines. And to be honest the capability of the technicians on site. Each dealership will tally the cost of the repair with diagnostic pictures and send it to corporate who will sign off on the repairs depending on the condition of vital components and or override them and prescribe a whole other protocal depending on active warranty plans, previous repairs, cost effectiveness and or guidelines of the class action suit.
      01-18-2019, 06:37 PM   #20
TeslaS
Drives: 2011 bmw 750li
What did you end up paying for all this? I’m in a similar situation.
      01-18-2019, 06:38 PM   #21
TeslaS
Did you get your car back yet? Any info on what you will have to pay, if anything?
I’m in a similar situation. What’s your mileage?
Thanks
      01-24-2019, 10:35 AM   #22
shawn938
Drives: 2022 X3MC
Has anyone gotten a replacement engine yet? If so how long did you have to wait. I have personally been waiting almost 8 months for a replacement engine and keep getting run around by BMW corporate and my BMW service center. I didn't even use the class action for my replacement engine rather my third party warranty paid out for it. This whole experience has just confirmed why I won't be buying BMW cars ever again.
