02-08-2019, 05:07 PM | #69 |
Rep 965
02-08-2019, 06:09 PM | #70 |
Rep 1,299
02-10-2019, 06:32 PM | #72 |
Rep 116
When cruising in D, does it still climb into 8th gear at 40-45 mph with the flash? Can't stand that it turns 1200rpm at 45mph. There is no sport in that. When stock, if you switch it to sport, its in 5th gear at 45 or comfort 8th gear at 45, there is no in-between. Seems like 45mph should be 6th or 7th when cruising.
02-10-2019, 08:49 PM | #74 |
Rep 1,299
02-11-2019, 12:01 PM | #75 |
Rep 182
Drives: 2015 BMW 650i GC
Does anyone know if this is compatible with the N63TU cars? I tried emailing them and no response...
02-11-2019, 01:29 PM | #76 |
Rep 42
not yet
2011 F10 535i N55 PWG 8AT | "Pureboost.de Tune" + MHD Flasher | xHP Stage 3 Transmission Tune | N20 3.5bar TMAP Sensor | Pure Stage 2 Turbo | GFB DV+ | Fuel-It Stage 2 LPFP | 93 Octane Fuel | BMS Intake | ER 4" CLess D/Pipe | ER 3" Charge-Pipe | Wagner-Tuning Competition Intercooler | Custom Turbo Inlet Pipe | https://i.imgur.com/iR4wm3I.jpg |
02-11-2019, 01:30 PM | #77 |
Rep 1,299
02-11-2019, 02:59 PM | #78 |
Rep 2,416
02-11-2019, 04:42 PM | #79 |
Rep 182
02-14-2019, 10:04 PM | #80 | |
Rep 1,299
02-15-2019, 12:07 AM | #81 |
Rep 34
For those who like charts. Here's how the xHP tune compares to the stock transmission tune for the ZF8HP on a 335i.
Found at: https://bmw.***********.com/threads/...detailed.4252/ |
02-15-2019, 06:38 AM | #82 |
Rep 1,873
Just FYI for all:
I've been chatting with them because my car does not have DEC (COMFORT/SPORT switch). I don't believe they explicitly designed maps for this, but I've sent them some logs from my TCU and they've said they'll work on something. For me I would probably be going Stage 2, and would take Comfort/D in D, Sport/S in S and Sport+/M in M put together as a "no DEC" section. Has anyone without DEC tried xHP? |
02-15-2019, 07:29 AM | #83 | |
Rep 1,299
02-15-2019, 09:48 AM | #84 |
Rep 1,873
02-15-2019, 10:30 AM | #85 |
Rep 1,299
D is much more fun almost as if I am in sport mode with short gear ratio. S mode shifts super quick plus keeps rpm in the range where power comes almost immediately. Manual mode is so.much fun now why, well, because now when you pull the lever down to change gear, it does it immediately. Before I would pull the lever down to change gear and there would be a delay and that delay is gone. Shifts are on point, plus increased line pressure is another reason to get it if you tuning your car.
02-15-2019, 11:18 AM | #86 | |
Rep 1,873
02-15-2019, 11:21 AM | #87 |
Rep 1,299
I did not see revs that high between stage 2 and stage 3 in S mode. I think they referring to sport+ mode.
02-16-2019, 11:34 AM | #88 |
Rep 151
Does the XHP tune keep the revs in the sweet spot of the powerband? For example most 1/4 mile guys short shift short around 63-6800 as the stock turbo drops off and is less efficient up top. I don't see the need to run to redline for 90% of my driving unless I'm trying to hold it in gear through a corner and then I would be in M mode and a flash wouldn't assist me there.
2015 F10 535i | BM3 STG 2 91 Octane | VRSF 4" DP | GPlus FMIC | Eibach SwayBars | H&R Springs | NGK 97506 .020"
