2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes 11 550 Msport
      12-09-2023, 12:35 PM   #1
headache876
Drives: F10 550xi
11 550 Msport
Can the X drive support running a 275 35 20 on all four corners? My car is running the Niche M158 Form and they are 8.5 wide
      12-09-2023, 02:50 PM   #2
Unspec
Unspec's Avatar
1301
Drives: 2015 BMW 535xi
Depends, but not because of xDrive. Unless you have some super aggressive offset wheels, a 275/35/20 will not fit up front. The only way to have them fit would be to create a ton of poke via really aggressive offsets, but if you're into that, then send it.
What's the offset of your Niche's?
2015 BMW 535xi
ISTA VM Setup/Tutorial
      12-09-2023, 03:51 PM   #3
headache876
Drives: F10 550xi
They are a +35 offset, I’m thinking 245 35 20 up front and maybe a 285 35 20 in the rear only if it’ll support the 285
      12-09-2023, 07:05 PM   #4
Unspec
Unspec's Avatar
1301
Yea, 275's up front will not fit with that offset.
I rock 245/40/20 F 275/35/20 R with 343M's, if that helps.
F: 9" +34
R: 10" +34
2015 BMW 535xi
