2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum Oil in breather tube ?
      05-14-2018, 09:27 PM   #1
supraken
Drives: car
So while doing the spark plugs today, I had to remove the charge pipe. There was a breather tube that needed to be unplugged, and there was a fair amount of oil in it. Is this normal ?
On some of my previous cars this seemed to be a normal thing, but want to confirm this is nothing to worry about.
      05-15-2018, 05:46 PM   #2
5soko
5soko's Avatar
333
Drives: M5
FWIW, you are not suppose to remove the pipe from the cylinder head, bmw warns of damage to the cylinder cover if you do this.
Current: E63S AMG 4matic RENNtech || M5 Evolve..Eventuri || F10 LCI 535i MHD
      05-18-2018, 01:54 PM   #3
supraken
Drives: car
Interesting .. was just following instructions from a forum post for doing the spark plugs (needed to remove the intake to get to the back cylinders).
Why would it damage the cylinder cover though ?
      06-13-2018, 10:33 PM   #4
pleeson
pleeson's Avatar
Drives: 2017 540i XDrive
Mine looked just like that on both N55s I've done it on.
I'm impressed you could get that off without it breaking - the clips and tube itself can be pretty brittle.
As long as it's intact, I see no problem removing it, and can't see how it would damage anything.
      06-13-2018, 11:00 PM   #5
supraken
Drives: car
Yeah, it was really brittle, it was a PITA to get it off without the whole thing just disintegrating.
So sounds like the oil is normal and nothing to worry about ?
      06-17-2018, 03:20 PM   #6
pleeson
pleeson's Avatar
In my experience, yes.
In many other, older cars I've often seen some oil in the PCV valves and tubes as well.
      08-12-2018, 11:42 PM   #7
matroxstock
Drives: 2011 BMW 535i
Breather tube removal
One way to get the breather tube off is to take the 4 tabs one at a time, pry them up slightly with a small screw driver and put a piece of wire under the tab to hold it above the ridge. Once you do all 4, the tube connector will pull right off.
I actually replaced my tube with a small piece of rubber heater hose and hose clamps. I kept the breather tube connectors on each end along with the heater circuit. My Breather tube had cracked.
      08-14-2018, 07:52 PM   #8
Kubie1
Drives: F10 550i
Oil in the PCV system is fairly common!
