2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Navigation, iDrive, Audio, Video, Bluetooth, Phone, Coding Retrofit of Reversing Camera
      10-30-2012, 11:53 AM   #23
bemetas
Drives: f10
reversing camera
Originally Posted by sunnyUK View Post
I got the parts/instruction etc from BimmerTech above
Hello I am Spanish and Sorry to bother you but the forums does not come as Spain mounted reversing camera
I'd like the number of reference indicases bracket reversing module Spain finds any BMW dealership by reference and can not ask me
thanks
      10-30-2012, 11:54 AM   #24
bemetas
Drives: f10
thanks
      11-04-2014, 01:30 AM   #25
VitaminXX
Drives: BMW E39 525i
Hello
do you remember where did you connect the pin 4 and 5 to (Green and Orange/Green) ?
The green cable is the retrofit cable after i pushed it in. It was odd that a fuse was in there when there was no connection!
Did you manage to remove the rear seat side bolster?
      11-10-2014, 09:40 AM   #26
jpcampa
Drives: BMW F31 M
Hi! I'm Juan from Spain. Last weekend, I installed a colleague a camera rear view at its 5 series (F10) with a retrofitted navigation CIC 609 but without PDC.
After coding and review installation and coding again and again, everything was ok, but the camera did not work at all.
Anyone know if we must have original PDC to make this retrofit ??
Thanks in advance
JP
      10-27-2016, 02:13 AM   #27
egisz
Drives: BMW F10 525d 2010
Thanks in advance
JP
Hi Juan,
Did you manage to make reverse camera work?
I have same problem big navigation, no PDC and would like to retrofit camera.
But I would like to know if you succeeded?
Egidijus
      10-27-2016, 02:10 PM   #28
Teq
Drives: E90
It won't work you need pdc or use an emulator.
      10-31-2016, 04:24 AM   #29
egisz
Thanks Teq.
At least good to know before started.
      01-07-2017, 12:22 PM   #30
PaulT9090
Drives: 520 F10 M Sport
2013 BMW 520d  [0.00]
I've recently bought my F10 520d and love it! When bought, from a BMW franchise, the reversing camera worked just fine. After only 3 days it has failed. Whilst all the lines are displayed, there's no picture. Naturally, I took it back and they're having a problem. The unit is a retrofit and not a BMW original. They're willing to do something, just don't know what! Is it likely to be just a camera fault? Have you come across this problem before?
      01-07-2017, 03:10 PM   #31
claykin
Drives: various BMW
Is the retrofit the OEM reversing camera?
If so, check the fuse to the camera module. If the fuse is OK, I will tell you it can be one of several things considering its a retrofit.
poor power wire tapping
poor grounding
poor connection from cam module to canbus
poor video connections at back of iDrive head unit
bad camera
bad camera cable
bad camera module
Apologies, but honestly, I'd use the above as a troubleshooting guide.
2023 840GC | 2021 740i | 2019 X3
      01-09-2017, 06:24 AM   #32
PaulT9090
Thank you. I'll have a play at the weekend after I've got rid of this dam ManFlu!
      03-25-2017, 06:46 AM   #33
berndh
Drives: BMW F11 525d
Does someone have the PN# for the bracket only for an F11? I have all the parts but missing the bracket and can't find it on ETK. The bracket looks different from the one above.
Thanks
      05-20-2018, 10:44 AM   #34
Simonwt
Drives: 520 D m sport plus touring F10
Advice
Good afternoon all I’ve just recently purchased a 520D m sport plus touring with professional media etc, I have the reverse system set up but would like to retrofit a camera how much will this cost me please and how easy is it to do ?
My car is a 2015 F10
Cheers
Simon
      10-28-2018, 11:49 AM   #35
Magoo92
Drives: F11 520d Tourer
Does anyone know the part number and how much BMW charge to fit this ? I travel most weeks with work so time is short to do this myself and I would consider it if it was not extreme price wise.
ManY thanks
