2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Navigation, iDrive, Audio, Video, Bluetooth, Phone, Coding BMW F10 Coding DIY (and other Fxx models)
      03-20-2017, 07:04 PM   #221
renew82
Drives: 528i xdrive
New BMW owner.
Hello,
I'm a new BMW owner that is interested in learning to code. May I get some info on where to download the proper files? I have a cable coming from Amazon.
TIA
Sean
      03-20-2017, 08:13 PM   #222
shawnsheridan
shawnsheridan's Avatar
Drives: 2018 Alpina B6 650ix GC
Originally Posted by renew82 View Post
Hello,
TIA
Sean
PM sent.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant
2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE
      03-29-2017, 11:16 AM   #223
imraank7
Drives: BMW 520D Msport 2011 F10
Esys Download Link
Hi Am new here,
I have a BMW 520 D Msport F10 2011 I am looking for esys download link as I want to code few things on my car can anyone help? sorry if this has already been asked before but I cant find the link anywhere
      03-29-2017, 11:32 AM   #224
shawnsheridan
Originally Posted by imraank7 View Post
Hi Am new here,
PM sent.
      04-04-2017, 07:50 PM   #225
renew82
Drives: 528i xdrive
Thank you for help with coding
Hello, Thanks to all on here for the plethora of information and help I received with the software setup. I finally got it all figured out and have coded the car.
      04-04-2017, 08:20 PM   #226
shawnsheridan
      04-04-2017, 08:43 PM   #227
Almaretto
Almaretto's Avatar
2374
Drives: Test Vehicles
Originally Posted by johnhva View Post
There are probably 10 or more mods I'd like to code eventually but I'm looking first for the specific code and step-by-step procedure to delete S5AP and enable the Euro anti-dazzle LED high beam function on my LCI 2014 F10. I've found code for Enable auto high beam default but not specifically for the anti-dazzle enable. Anyone have a link?
NGHB does not work with just VO coding on F010's. It is theorized, but untested, that programming is required.
      04-25-2017, 01:18 PM   #228
joshhu
Drives: F10 528i LCI M Sports
I got my ENET cable today, and where do I start?
Hello,
I got my ENET cable today, and I have downloaded the e-sys 3.28.1, I also downloaded the psdzdata 61.2.0500 lite version, everything seems to be ready, however so many things come up to my mind before I dare to code.
1. What are Launchers? I have seen many website providing Esys Launchers to download, do I need them?
2. I also found a Chinese software call esysplus, what is that?
3. What is EST token? What is that used for?
4. What is ISTA-P? Do I need that?
5. Before the version 3.27.1, there is a patch coming with the package, and it seems you need to use the patch to make esys work, but i don't find the patch in esys 3.28.1, how come?
Sorry i have so many questions. I just want to make sure i have everything needed in hand
Thanks.
      04-25-2017, 01:31 PM   #229
shawnsheridan
Originally Posted by joshhu View Post
Hello,
Thanks.
1) E-Sys Launcher provides .EST Token Solution and CAFD Mapping (Corrects Trimmed CAFD Data) to E-Sys, as well as E-Sys "Cheats" for simplified Coding.
2) E-Sys Plus is a similar Chinese Tool, but no where near as functional as E-Sys Launcher is.
3) .EST Token is required by E-Sys in order to invoke the FDL Editor (Make FDL Code Changes).
4) ISTA/P is Dealership Software for Programming (Flashing ECU's) and Encoding (VO Coding) them. E-Sys can do the same.
5) Patch no longer needed as .EST Token Solution is provided by E-Sys Launcher now.
      04-26-2017, 03:16 AM   #230
joshhu
Shawn,
Thank you so much for the answers. I came across some problems while installing E-sys launcher.
1. I installed e-sys 3.28.1 and it went well.
2. I then install e-sys launcher premiere, and it went well too.
3. When i started e-sys launcher, the program prompted me for activation code, which i didn't have one
4. I jsut followed the instructions and sent an email to TokenMaster, but still got no reply
5. Can i just run e-sys 3.28.1 with token that was generated by token generator without launcher
Thank you very much
      04-26-2017, 06:55 AM   #231
shawnsheridan
Shawn,
Thank you very much
No, you can't. You must use Launcher to validate that the token. E-Sys won't do it by itself. Thus, you must wait on Activation Code.
      04-26-2017, 08:29 AM   #232
joshhu
Hi Shawn,
Thank you for your reply, I think I must be patient to wait for the code to come.
Thank you again.
      08-15-2017, 07:15 AM   #233
Bruno112
Croatia
20
Drives: 2014 F10 530d MSport
I want to code blinkers in HUD and "Auto-on high beam assistent".
Do i have to code all this parameters to it works normal?
And is brake force correct for EU roads?
      08-15-2017, 03:54 PM   #234
Almaretto
Almaretto's Avatar
2374
You only need automatisch for HBA.
For HUD, yes, you must code KOMBI and HU_NBT.
For EU BFD, enabling is the same; but should be on from factory in EU vehicles with a few different parameter settings.
      08-23-2017, 08:56 AM   #235
spielnicht
Petrolhead
spielnicht's Avatar
440
I took the lazy route and got Carly. I was able to get done 99% of what I wanted done.
  • Video in motion? Check!
  • Disable Auto Stop/Start? Check!
  • Disable iDrive Warning Msg? Check!
  • Disable Backup Camera Msg? Check!
  • Enable Comfort Mirror Folding? Check!
The only other thing I wasn't able to do and I'd love to know if it's possible is enabling auto parking brake. I sorely miss this feature on my MB. I didn't see a mention of it in the coding guide. Anyone know if it's possible?
      08-23-2017, 09:23 AM   #236
Almaretto
Almaretto's Avatar
2374
I have not seen coding to enable auto-E-brake, but it will engage automatically if you use Auto-H. It auto-releases as well if seat belt buckled.
      08-23-2017, 10:25 AM   #237
DeividF80M3
DeividF80M3's Avatar
44
Drives: BMW F80 M3
2015 BMW F80 M3  [0.00]
Hi,
I have installed the same esys and version on two computers, and the laptop when I want to select the version of the car appears blank, someone knows why it happens?
Laptop win10
Someone can help me to download the latest version with the launcher?
      08-23-2017, 10:39 AM   #238
Almaretto
Almaretto's Avatar
2374
Originally Posted by deivid550xi View Post
Hi,
Laptop win10
Blank target only means one thing--you either forgot to download PSdZ or you extracted/installed incorrectly.
Coding: (No Request) Latest Software Links
      08-23-2017, 10:53 AM   #239
DeividF80M3
44
Drives: BMW F80 M3
Thanks, I'll try to download the PSdZ again
      08-23-2017, 11:51 AM   #240
Or outdated PSdZ... Or the cable is bad. I had that happen to me.
      08-23-2017, 11:54 AM   #241
Almaretto
Almaretto's Avatar
2374
Outdated PSdZ results in "not found [C012]" errors when "Read Coding Data" & vehicle I-Step is > computer PSdZdata.
Bad cable will make it difficult to connect via VIN, but target window will still be populated.
      08-23-2017, 11:58 AM   #242
DeividF80M3
44
Drives: BMW F80 M3
The cable is fine because on the other PC it works properly. In this Laptop has put the latest data...
