2010 2011 BMW 5 Series Forum F10 M5 M Performance Steering Wheel can be installed on 528i? |
02-19-2017, 11:05 AM | #1 |
Rep 3
Hello Folks,
Does anyone knew that below M5 Steering wheel can be installed on 528i? Meanwhile, I have been using this M Performance steeting wheel and I am gonna replace to the M5 one, may I ask is that I also need to replace below items apart from the airbag? Items need to be change? 1. 61-31-7-848-639 x 1 CONTROL UNIT, STEERING WHEEL ELECTRONICS 2. 61-31-9-218-399 x 1 ROCKER-TYPE SHIFT LEVER, LEFT 3. 61-31-9-218-400 x 1 ROCKER-TYPE SHIFT LEVER, RIGHT 4. 61-31-7-849-409 x 1 SWITCH, MF STEERING WHEEL, M-SPORT 5. 32-33-7-849-416 x 1 VIBRATION GENERATOR 6. 32-30-7-848-270 x 1 COVER FOR STEERING WHEEL, REAR 7. 32-30-7-848-330 x 1 CONNECTING LINE, STEERING WHEEL 8. 32-30-6-861-999 x 1 HEX BOLT 9. 32-30-7-848-333 x 1 SET OF SCREWS 10. 32-30-7-850-622 x 1 ACOUSTIC FOAM PART Thanks so much, |
02-20-2017, 06:58 AM | #3 |
Rep 14,521
i think i ran across a thread some time back but i believe you would need a new airbag if the wheel you order or get doesn't come with one? also, all the plugs have to be straight plug and play which i don't recall if they are. and coding would be needed. i swapped mine out with a custom Ledermanz steering wheel which i was able to reuse my airbag and connections. i tried doing a quick search for you but couldn't find anything regarding M5 steering wheel retrofit to a F10
02-20-2017, 12:47 PM | #5 |
Rep 76
I am confirming that it will. I have done it on mine (535xi-2013) and used M5/M6 Steering wheel, exactly the one that is featured on the picture above. You will have to purchase the Air Bag and Steering Control Module, as the one in current wheel won't fit. Word of advice if are planning on using www.realoem.com for part number. For my model the Steering Control module had an identical part number from non-Sport wheel to M5/M6 steering wheel-should work and I learned from other member that it's a typo and won't fit. Therefore buying another one was required. You might have to buy all other pieces to make a full assembly, all depends on M5/M6 wheel you are getting.
2013, 535 XDrive, 112k miles
1997, 328is, 335k miles - Retired 1998, ML320, 200k miles - Sold 2018, Q5, 100 miles 2005, XC70 AWD, 160k miles |
02-21-2017, 08:08 PM | #7 |
Rep 18,751
Yes, it can be done.
EL Jeffe 5612.50 |
11-09-2018, 06:04 PM | #8 |
Rep 3
I want to install that steering wheel on my 2014 F10 550xi.
What is the steering wheel control module I need? Can you pls give me a part number. I did some research and I read sometimes pin 11 (earth) is missing and the wheel wont power up. Is that why you need a new control module? Thx |
11-10-2018, 05:22 PM | #10 |
Rep 3
No, I want to buy one and install it in my 550.
Before I buy it I want to make sure it works. I’ve seen posts saying it does but you need extra parts because sometimes the Steering wheel doesnt light up. |
11-11-2018, 09:04 AM | #11 | |
Rep 214
11-11-2018, 04:46 PM | #12 |
Rep 3
I have a wheel that looks like the M Performance one but w/o lights and race display.
It is the one that came in all 5 series with M package after 2014. I am willing to sell it after I upgrade. |
05-20-2019, 07:12 AM | #13 | |
Rep 9
930910 93090A Do you guys think it's because of the wheel not being plugged into the heating circuit??? Thanks |
