2010 2011 BMW 5 Series Forum F10 F10 Technical Topics DIY Guides & Discussions DIY: Wheel spacer install
      12-09-2012, 11:11 PM   #1
BigDeep1
Drives: 2011 535i Sport - P1, P2
This mod is as easy as changing a tire. For those that still may be a bit apprehensive, I took a few pics and made some notes for the install.
I installed 15mm Turner Motorsports spacers on the rear of my 2011 535i (F10). She has the 19" sport wheels with 275/35/19 rubber on the rear.
I am very happy with this mod as I feel that it gives the vehicle a more muscular look. There is no change in ride quality and no vibrations (I had someone sit in the rear and took her up to triple digits to check).
Before starting, make sure to apply the parking brakes! Also remember to recheck the torque on the lugs after 2 weeks of driving. BMW recommends 90 ft-lb of torque.
Materials I used for the install:
jack
anti-seize cream (found only in auto parts store)
wire brush
torque wrench
Here is the link to the pics and notes for the install:
DIY WHEEL SPACER INSTALL
      12-09-2012, 11:18 PM   #2
BigDeep1
Before - After
      12-10-2012, 09:58 AM   #3
MWPos
MWPos's Avatar
Drives: 2013 535i
2013 535i  [0.00]
Very nice! The "after" photo clearly shows how much better it looks.
Question: How did you decide on 15mm? I've read about ordering spacers and the ordering systems request that we measure the wheel's inset from a line drawn across the exterior of the wheel well. Did you do any measurements prior to ordering?
      12-17-2012, 02:36 AM   #4
ATOMBOY
ATOMBOY's Avatar
Taiwan
9
Drives: F10 520D
Excellent work done for your F10!
      01-01-2013, 12:55 AM   #5
BigDeep1
Thanks! I did not take any measurements before ordering. I read a lot of threads with various sizes of spacers. Most seem to do 12.5mm on the rear on the rear, but I have also read of some using 20mm on a lowered car. I thought 15mm would be the best compromise, and I think it was .
Thanks bro!
      01-07-2013, 03:35 AM   #6
donniemcm
Drives: BMW X5 F15
Newbie question : Do spacers have other use than cosmetic?
Thanks!
      01-10-2013, 07:35 PM   #7
JamRWS6
Drives: 2022 X3M Competition
Thanks!
They can help with clearance if needed when adding wider wheels, bigger brakes, etc
- 2022 X3M Comp
- 2021 X5 xDrive 40i
- 2018 F80 M3 (sold)
