2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications Weird issue I've had for way to long
      04-29-2015, 10:19 PM   #1
combatbmw
Drives: 20' X3M CP
Car hesitates when Im on freeway in comfort mode under 2k rpms.
If I hold gas just to maintain speed at anything below 2000 rpms My car jerks a bit, You can hear it too because I have a full exhaust system.
Did it stock (less noticeable because car is silent).
If I put car in sports mode and stay over 2k It doesnt do it.
No codes, took it to bmw even when car was stock and they couldnt figure it out.
Its annoying the hell out of me.
Any ideas?
2020 X3M CP - IND Reflector set | Ceramic Tint
Retired:2015 M5 CP MSR Intake|Carbon Fiber Fender Vents|Meisterschaft GTC catback with LXR mid pipes and ER Catless DPs | BPMSPORT Stage II Tune | RKP Rear Diffuser and Challenge Center piece |RKP Front Lip| Painted Reflectors | H&R Springs | Strasse SM5R Carbon Fiber Wheels | Nitto R888 |
      04-29-2015, 10:20 PM   #2
badblack550xi
badblack550xi's Avatar
check your PCV might be broken or valve inside broke.
2011 550i RWD 60-130 7.35
      04-29-2015, 10:23 PM   #3
combatbmw
Drives: 20' X3M CP
Interesting, Where is pcv and how would I test it?
Sorry for dumb reply I just dont have the slightest idea what a pcv is.
Thanks for input.
      04-29-2015, 10:25 PM   #4
combatbmw
Drives: 20' X3M CP
Also wouldnt it trigger a code if it was broken?
      04-29-2015, 10:43 PM   #5
badblack550xi
NAH ITS A SMALL PIPE IF IT LEAKS A LITTLE IT WONT THROW A CODE SORRY CAPS
      04-29-2015, 11:09 PM   #6
combatbmw
Drives: 20' X3M CP
Ill have it checked out tomrw. thanks
      04-30-2015, 09:33 AM   #7
///M5Driver
Drives: gaggle of BMW's
For what it's worth my 11' was documented with this same issue before and after the care package. According to the service manager it's a known issue BMW is trying to work on. I kick it into a lower gear to raise the RPM's and it goes away.
      05-05-2015, 04:49 PM   #8
Zer0Cool92
Drives: blue metallic
Any ideas?
I have the same exact issue. Did you find a solution? One shop told me it night be a exhaust sensor but I told them to leave it alone.
      05-05-2015, 11:00 PM   #9
combatbmw
Drives: 20' X3M CP
Its at Gintani right now getting looked at since they work on these types of cars I hope they find the issue.
BMW dealers all say they can't replicate the problem. I mean it is hard to catch because it only does it below 2k rpms on freeway while maintaining speed.
      05-05-2015, 11:05 PM   #10
Zer0Cool92
Ya I know what you mean. Mine does it when cruising 20-60 mph in high gear maybe 6 or 7 around 1500 rpm. Above 1500 and it's good. What exhaust setup do you have? And keep me posted please, I thought the issue was from my muffler delete causing too much loss of back pressure.
      05-05-2015, 11:18 PM   #11
combatbmw
Drives: 20' X3M CP
I have the Shetigen exhaust, but it did it w/stock too, just harder to notice because you can't hear shit.. But with an exhaust system you can here it as it hesitates.
I will keep u posted.
      05-06-2015, 01:50 AM   #12
valbmw
valbmw's Avatar
94
Drives: 2016 BMW F10 M5 CP 600 hp
Another member had the same choking issue at low rpm on his low-mileage M550d being on warranty. The dealer techs turned the car inside out, checked it top to bottom and even replaced the xDrive before the issue was found. That was: injectors.
Both N63 and N63TU need the injectors to be checked and serviced.
      05-06-2015, 02:47 AM   #13
dangom808
dangom808's Avatar
Drives: 2015 F10 528 M-Sport
Just got thru this issue. It was a bad coil. Replaced all 6 for good measure. Hesitation was more noticeable with increased load (i.e. Traveling uphill ).
Stating the obvious here but...perhaps a slight chance that's what you're experiencing ...just sharing my recent experience with same symptoms. Cheers.
      05-07-2015, 04:38 PM   #14
Zer0Cool92
Did you experience the throttle start to stutter around 1500 Rpms? If I'm heavy foot on the gas I don't feel it.
      05-08-2015, 03:01 PM   #15
Zer0Cool92
Did you hear back from gintani yet?
      05-08-2015, 03:03 PM   #16
Zer0Cool92
I did the CCP already.. They finished my car the next morning and allegedly replaced the necessary components. I was driving the crap out of the loaner, so something makes me think they just wanted me to return my car. That, plus it should've taken more than one day to replace the parts.
If it does turn out to be injectors with the old part number then bmw dealer will be hearing from me soon!!
      05-08-2015, 03:05 PM   #17
combatbmw
Drives: 20' X3M CP
No been to busy to deal with that.
As soon as I get my car back I will update you.
      05-15-2015, 11:27 AM   #18
Zer0Cool92
Hate to be a stiffler man but has gintani gotten back to you? I'm really tryna pin point this issue on my car lol.
      05-15-2015, 11:47 AM   #19
combatbmw
Drives: 20' X3M CP
No luck.
      05-15-2015, 02:34 PM   #20
Zer0Cool92
No luck.
You didnt hear back? Or they couldn't find the issue ? If it's the injectors I wonder if they'll replace them again under the CCP
      05-15-2015, 03:18 PM   #21
combatbmw
Drives: 20' X3M CP
IDK if the n63tu has the same ccp as the n63.
I did hear back, they couldnt find the issue. So for now im dealing with it, like I have been for a year.
      05-15-2015, 07:38 PM   #22
Zer0Cool92
Did you notice the hesitations above 1500 rpm?
Where did you get the replacement coils from?
