2010 2011 BMW 5 Series Forum F10 F10 pulling to the right... |
04-25-2011, 11:39 PM | #463 |
Rep 19
Car back in shop for the third time in three weeks for pulling to the right issue. Dealer can not figure out why it is pulling....they actually gave me my car back with the steering wheel off centered....right front overinflated and left front under inflated. Trying to normalizing the pulling to the right.
I am calling bmwna tomorrow. This is getting a little ridiculous. |
04-26-2011, 08:11 AM | #464 | |
Rep 6,696
1. He's "not sure what the software patch installed by selling dealer (other than his) was for as that wouldn't affect the steering unless I had active steering.". Mind you, the car has already been in for service here once for 5 days. Didn't he think to check the service history? 2. Wants to rotate on "smaller wheels, as larger wheels tend to follow the crown more". 3. Wonders if it could be an "issue with one of the tires" as "different tires have different rolling resistance". Uh, I bought the car with the OE Goodyear Excellence RFT's and then THIS DEALER installed the Conti DWS's I have on there now on the OE wheels. Shouldn't they have accounted for that before? 4. Wants to drive another sport equipped 535 on same roads to see if it's the same. Yeah, so would I, let's go for it. Not getting the warm and fuzzy here. I also noted the typical dealer BS on my previous workorder: 1. Under steering pulls to the right they noted "could not replicate". Uh, I drove with the shop foreman before, during the 5 day stay, and he noted it. 2. Shifter would not go into Manual / Sport gate until it was pulled multiple times "could not replicate". Uh, I gave you a freaking VIDEO of the issue. |
04-26-2011, 01:02 PM | #466 |
Rep 20
I reported in earlier posts that my car has the same pulling to the right issues. I went to my dealer and they called directly to the BMW Engineers who stated that the car had weak Camber bolts, this was 3 or 4 weeks ago, the Camber bolts arrived yesterday and my car is at the Dealership as we speak, I should have the car back after work today. I will let you know if this solves the problem.
04-26-2011, 01:32 PM | #468 |
Rep 20
I will keep everyone posted for sure! What I thought was intresting was my dealership didn't mention anything about software upgrade / re allignments or tires being the issue as everyone else has reported. I took the car in the dealership they called me back said per the BMW engineers the car had weak camber bolts. It's not like this is the second or third attempt by the dealership to fix this.
04-26-2011, 03:21 PM | #469 |
Veteran
Rep 45
It seems that BMW is making headway on the right hand pull problem as every production month goes by, but the problem isn't resolved yet. My first F10 was built in May-10 and it was awful. Every attempt to correct the problem failed. My second is a Nov-10 build. Direct, out-of-the-box, it was much better - just a mild drift. I took it in the the dealer last week for a few other things and asked if there were any new tweaks (software fixes. etc.) that had been released since I took delivery of the car in December. Apparently there were. A software update was done to the steering angle sensor. My car now drives dead straight - not even a hint of a pull - none of this "crown of the road" crap.
Now, if they could just do something with the jerky throttle, other than just a temporary reset...
2011 F10/535i Space Gray ("v2.0"), ZSP, ZAV, ZCV, ZDA, ZPP, ZP2, NASW, 465, 464, 4NB
2011 F10/535i Space Gray ("v1.0") ("Ain't my problem no mo'...") 2008 E60/528i (Retired) |
04-26-2011, 07:22 PM | #470 | |
Rep 6,696
04-26-2011, 10:06 PM | #471 |
Rep 22
Got my car back from the dealer a few days ago and the pulling to the right ang vague center feel steering issues seem to be improved. I'd like to drive on some road surfaces and conditions (strong cross winds) that manifested these problems before I can definitively say whether the problems have been resolved.
04-27-2011, 06:51 AM | #472 | |
Rep 6,696
04-27-2011, 10:23 AM | #473 |
Rep 20
Here is what they did to my car: re aligned the car, 3 of the 4 wheels where completely out of whack, they also put different/new/updated camber bolts on. I can report that the car does drive straight in town and on the highway! I need a little more time to be sure this is a permanent fix, I would like to see how it does in cross winds, and different surfaces, so far so good, but then again it’s only been 1 day
04-27-2011, 11:20 AM | #474 |
Rep 722
RLM, when you say 3 out of 4 wheels were out of whack do you mean camber wise or were they not balanced properly? I know it seems like a stupid question since you said it's alignment but I didn't want to assume. So the bolts are they going to be called back for or is this something someone has to complain about to get? You said they were ordered from Germany, do you have the part number? Or if you can upload your worksheet it would help a lot. Thanks and let us know how things go in the next few days. I am sure everyone with this issue is following this thread.
MBA |
04-27-2011, 01:12 PM | #476 |
Rep 20
Build Date: Late December 2011 MODEL: 535xi
The Camber was out of Whack not the wheels. I attached the work order as well as the Camber adjust that were made. Hope this helps! |
04-27-2011, 01:42 PM | #477 |
Veteran
Rep 45
The work order is at home - I'll get the details and post them tonight.
04-27-2011, 03:01 PM | #478 |
Rep 515
LOL guys I am actually having this same problem on my 2010 E90 328i. Many alignments have been done and my car still pulls to the right side of the road. My steering wheel is perfectly centered but with just holding the steering wheel i can feel and see the car while accelerating and just crusing wanting to point to the right. It is very annoying. I ordered a brand new set of Continental Extreme DW tires that will be installed tomorrow. I hope new tires and having the car realigned will fix this problem. It is VERY annoying.
2013 F10 BMW 535i Alpine White / Oyster Dakota Leather / Anthracite Wood Trim / Steptronic transmission / M Sport Package / Premium Package / Technology Package / Rear-view camera / Park Distance Control
04-27-2011, 03:13 PM | #479 | |
Rep 70
I thought for a moment to trade my car for a xdrive model to avoid this overpowered steering wheel..... |
04-27-2011, 07:21 PM | #481 |
Rep 6,696
04-27-2011, 07:21 PM | #482 | |
Rep 6,696
04-28-2011, 07:38 AM | #483 |
Rep 515
I know all cars will have a small amount of pulling to the right, Well not PULLING but more lift a drifting. My 328i pulls. So I just decided to ditch the run flats which cause the car to tramline a lot more than normal tires. Getting the new Continentals installed right now and having the car alignment checked and realigned if needed. Hope this helps my car out.
04-28-2011, 08:43 AM | #484 | |
Rep 6,696
