2010 2011 BMW 5 Series Forum F10 2014 bmw 550xi + BMS stage 1 |
01-25-2014, 01:44 AM | #67 |
Rep 159
The more I read this, the more confused I get. Catless downpipes, N63, boost leak, N63TU, check this link, look at that graph, power drop, under rated, over rated, stageII but not for 2014...!!
I'm looking for a very simple answer to a very simple question, someone please help: A stock 2014 550i makes 445hp at the crank according to BMW. In layman's terms, how more power does the BMS Stage1 tune add? I wish they would post this simple answer on their website, like Dinan does, vs posting graphs. The consumer cares about the delta I would imagine. +50hp? +75hp? Just looking for a simple answer, and a number really. Thank you! |
01-25-2014, 02:15 AM | #68 |
Rep 1,250
Drives: 20' X3M CP
Varun like I've told you and someone else. There is a thread on this forum section. Under engine and exhaust that says N63tu stage 1.
All the info is there. Tune is adding 60+hp |
01-25-2014, 02:28 AM | #69 | |
Rep 2,416
2011 550i RWD 60-130 7.35
01-25-2014, 02:35 AM | #70 |
Rep 1,250
Drives: 20' X3M CP
Stock was 408 on this dyno. Std.
So top numbers on the right are sae/ std left. Hp only Bottom numbers are sae hp/tq |
01-25-2014, 01:41 PM | #71 |
Rep 159
01-25-2014, 06:04 PM | #73 | |
Rep 1,250
Drives: 20' X3M CP
I had a recall on the software on my car.. Went to BMW and updated After that went to dyno and car still dropping but after 5500 Instead of 5000k in the above graph. Today I installed full exhaust.. After I let car adapt I will redyno. I really feel like having catless downpipes with stock exhaust hurts performance on our cars because the 550i is a luxury car and Is extremely restricted. So the quick boost and surge of exhaust air from going catless to a wall of restriction may be the prime target. I will know in a few weeks after I let it adapt to the free flow. M5 has gains from the catless downpipes with stock exhaust because the stock system that comes with the M is a 3 inch piping with no resonators. And high flow mufflers. So when they go catless I think the car let's out the extra exhaust easily vs the 550i. But who knows. |
01-25-2014, 07:21 PM | #74 |
Rep 1,300
Yea. I get what you are saying. What is the standard rule of thumb for our cars to adapt to bolt ons or tunes? Instant? 20miles? 50 miles? Does it help if you drive the car aggressively in order to help it adapt better?
01-25-2014, 07:55 PM | #75 |
Rep 1,250
Drives: 20' X3M CP
Serge would have an answer to that. Aka bad Russian
01-25-2014, 11:06 PM | #77 |
Rep 2,416
Id say up to 500 miles to adopt to tune... And after than with in 10 miles what you have to do is the ecu reset and ten drive hard car feels brutal. I will start posting all the tips on my forum booostednation.net for the 550 cars
01-25-2014, 11:23 PM | #78 |
Rep 2,080
Most piggy back tuned turbo BMW adaptation has been around 50-100 miles of driving, with 15-20 hard pulls in 2-4th gears through redline....I've had 2 tuned 135i's, a tuned 335i, and a tuned 335d and that was my experience. N63 should be no different.
01-25-2014, 11:25 PM | #79 | |
Rep 2,080
01-25-2014, 11:46 PM | #80 |
Rep 1,250
Drives: 20' X3M CP
Id love to know what your talking about let me know when you post it. I wanna try that.
2020 X3M CP - IND Reflector set | Ceramic Tint
Retired:2015 M5 CP MSR Intake|Carbon Fiber Fender Vents|Meisterschaft GTC catback with LXR mid pipes and ER Catless DPs | BPMSPORT Stage II Tune | RKP Rear Diffuser and Challenge Center piece |RKP Front Lip| Painted Reflectors | H&R Springs | Strasse SM5R Carbon Fiber Wheels | Nitto R888 | |
01-25-2014, 11:47 PM | #81 |
Rep 1,250
Drives: 20' X3M CP
Yes hence better flowing oem system. So Downpipes can do there jobs. vs 550s that kill the cars flow. and possibly hurting the downpipe gains
01-25-2014, 11:48 PM | #82 |
Rep 1,250
Drives: 20' X3M CP
01-26-2014, 07:58 PM | #83 | |
Rep 1,300
So after 500 miles rest ECU? Then I drive hard for 10 miles? |
01-26-2014, 09:37 PM | #84 | |
Rep 1,250
Drives: 20' X3M CP
01-27-2014, 09:33 AM | #86 |
Rep 8,808
I've put close to 500 miles on my 2014 550 on the revised Stage 1 tune and this thing is a straight up monster. I have way more power than grip that my 245's snow tires could handle. On the highway going 40ish and in 3rd gear when i punch it in 3rd gear the traction control lights goes off like mad. This is where i miss my awd. I can't put the power down with the RWD setup now.
Alan
01-27-2014, 09:40 AM | #87 | |
Rep 2,080
I am on 245 Michelin A/S 3's and I was lighting up traction control in 1st and 2nd gear at any speed below 40-45 mph. Granted it's cold, but I have an awd. Will text you later re: dyno. Waiting to hear back on availability. Really wonder how the S1 TU feels vs. the S2 pre-TU, let alone how it dyno's and how the compare side vs. side. |
01-27-2014, 09:42 AM | #88 | |
Rep 2,080
If you have a bavarian technic cable, you can reset the ecu (which means resetting all ECU adaptations) through the software. |
