2010 2011 BMW 5 Series Forum F10 F10 Technical Topics DIY Guides & Discussions BMW F10 Coding DIY (and other Fxx models)
      02-12-2013, 10:05 PM   #45
Travel4surf
Travel4surf's Avatar
13
Drives: code F10
To start car without holding break down with your foot:
Change both values to, ->nicht_aktiv
CAS -> 3000 TC -> TC_STARTLOCK_BRAKE
CAS -> 3000 TC -> TC_STARTLOCK_DRIVINGREADINESS
      02-13-2013, 02:08 PM   #46
nugent
nugent's Avatar
Drives: f10 m5
don't think i'd disable that saftey feature.
e92 m3 6MT, RS4 6MT, S4 Avant 6MT, WRX 5MT, Corsica
      02-13-2013, 06:57 PM   #47
johntomferg
Drives: Formerly drove a 13 F10 M5
For those messing with the HUD turn signals, an interesting thing I have found is that somehow the "profiles" are linked to whether they work or not. If you program them and they seem to only work some of the time, go into the profile menu and switch to one of the other profiles (even if still named '----' by default). You'll find one where it is 'working'. Unsure if this will happen with any other settings, but figured I would share my experience.
REF:
HUD TURN SIGNALS
KOMBI -> 3008 -> HUD_PIA_BLINKER -> aktiv
KOMBI -> 3008 -> BLINKER_HUD_ENABLE -> aktiv
HU_NBT -> 3000 -> HUD_TURNSIGNAL -> aktiv
Display turn signal indicators in the HUD
      02-14-2013, 10:53 AM   #48
jmh
Internet Crash Test Dummy
jmh's Avatar
Drives: F97 X3MC / F80 M3 / F90 M5
I would think some of the coding settings are tied to the profile you had activated while coding the car.
I've never confirmed/tried as I haven't used the other key yet
Now the interesting test would be if the settings would move with the profile to another car (doubt it)
21 F97 X3MC Toronto Red/Black and more | 18 F80 M3 Tanzanite Blue/Amaro/CCB and more
15 F10 M5 Individual / Brilliant White / Extended/Full Cohiba Brown (Exec/Driver/B&O/20") / A few Euro add-ons / Stealth K40 / Upgraded B&O / ///M Performance Carbon Interior Trim / IND / Akrapovic Evolution Exhaust / HRE S107
      02-15-2013, 05:04 AM   #49
johntomferg
I haven't experimented with the profile export function. Might try it today and see what the file type is. Probably a binary, but might get lucky and it be a compressed XML or something...
      02-23-2013, 06:33 AM   #50
X5Blair
Drives: X535d; M2, M3, M5, 540d, AMV8V
Originally Posted by nugent
ok I figured it out. default for my car is nicht activ and werte = 1 for CAF. changing to activ automatically sets werte = 0. leave it that way and it will work.
cheers.
This worked!! Thanks!!!!
      09-13-2014, 03:08 PM   #51
Pmarszal
Drives: 2011 BMW 528i
Hey Bimmer fans,
Real quick question, do i need to install token for E-SYS? I heard mixed answers to this. Some people say yes and some people say no if you are just coding.
      09-14-2014, 02:04 PM   #52
snj1013
Drives: 2011 528i
For VO coding, a token is not needed. Most coding is FDL coding and a token is required.
      03-12-2015, 04:26 PM   #53
Makky
Drives: F34 340i
Quick question.
Anyone got an update on changing the units on the sports display (F10/11)?
      04-08-2016, 07:36 AM   #54
satzinger
Old BMW Fan
Drives: BMW 550i 2013
Can no longer code after a software update!
I have a F10 550i 2013; I had the car at the dealer for some work and they updated the software on the car.
Because of that I lost my coding. No problem, I thought, I just redo it.
I can connect, activate, read the ecu but when I try to read any data I get an error that it can't read it.
Does anyone have experienced this before?
Btw: I am using Esys 3.27.1
      04-24-2016, 02:29 PM   #55
manyoo99
Drives: 535xi M Sport
I have changed cars from F36 to F10 and have successfully programmed most things. However, I am having challenges finding 2 settings, as F10 does not have FEM_BODY:
1. Programming Triple Blinkers for turn signals. Default is 3. On the F30, this setting is in FEM_BODY, under "BLINKZYKLEN_ANZAHL_TIPP". Looking for the F10 setting.
2. Also, what is the F10 equivalent of "CM_LOGIC_R_OFF_DOOR". This is to turn off Radio and Navigation when driver door is opened.
      04-24-2016, 10:20 PM   #56
I don't think the number of blinks is adjustable for the F10.
The F10 is the same as F30...
      06-30-2016, 01:04 PM   #57
NV GUNS
NV GUNS's Avatar
Drives: 19' M2C
2023 M550  [6.75]
2019 M2 Competition  [0.00]
2002 330ci  [0.00]
Worked like a charm thank you!
      07-22-2016, 12:26 PM   #58
Fast400
Fast400's Avatar
Germany
683
Drives: iX M60
2014 BMW  [0.00]
Has anyone figured out how to increase the blinks?
It has to be possible!....logic says so.
      08-18-2016, 09:16 PM   #59
bradM235
bradM235's Avatar
Drives: 2014 M235i Estoril Blue
2014 BMW M235i  [0.00]
iDrive Start Screen Animations
For anyone that is wondering how many start screen animations there there are and what they look like, I've put together a playlist:
https://www.youtube.com/playlist?lis...218z-oP0TnN-HF
Enjoy!
NV GUNS57.50
      08-18-2016, 10:28 PM   #60
NV GUNS
NV GUNS's Avatar
Drives: 19' M2C
2023 M550  [6.75]
2002 330ci  [0.00]
Enjoy!
Awesome! I was wondering what the other ones looked like. The ///M is what I use and not very impressed by the Rolls startup.
      08-18-2016, 11:32 PM   #61
Enjoy!
Do you have the codes for those? Are they NBT only? Any special start screens for the CIC?
TIA!
      08-23-2016, 12:18 PM   #62
bradM235
bradM235's Avatar
TIA!
They were recorded on an F22 in the following module:
HU_NBT 3001 startup_emblem
      09-07-2016, 07:47 PM   #63
Almaretto
Almaretto's Avatar
2374
Drives: Test Vehicles
TIA!
Animation does not work on CIC. Must have NBT.
      09-07-2016, 11:29 PM   #64
Thanks...
      09-08-2016, 12:03 AM   #65
Almaretto
Almaretto's Avatar
2374
Thanks...
But do you do get Weather Band, which NBT does not
      09-08-2016, 07:35 PM   #66
I don't think I've ever accessed that... Not sure if I know how!
