2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes Bridgestone Turanza T005 or Michelin Primacy 4
      05-31-2021, 05:03 AM   #1
mrmarie
Drives: BMW F10
Hi,
I will change the tiers and there is two options (Bridgestone Turanza T005 97W or Michelin Primacy 4 97W)
any recommendation please
Thanks
      06-10-2021, 12:57 PM   #2
bemvejc
Drives: F11 525d
in which dimension ?
      06-15-2021, 01:21 AM   #3
mrmarie
Drives: BMW F10
Hi
Its R17 225/55
      06-30-2021, 06:04 AM   #4
thomaseckl
Drives: BMW 535xd F11
Hi,
is it possible to use used tires on the front and new on the rear?
Or should all 4 tyres be changed at the same time to avoid damages on x-drive?
      07-03-2021, 02:53 AM   #5
Johnkwick
Drives: F10 LCI
Both are in the same league
At least in my experience, I prefer Bridgestone T005 over Michelin P4
T005 is very quiet and smooth
      09-07-2021, 09:54 AM   #6
mikeojibwa
Drives: bmw f11 xdrive 2015
to my knowledge BMW recommends the difference in wear to be max 2 mm in between the 4 tires for xdrive. Moreover, is better to be same brand, model and size to avoid weight and road behavior differences to compromise xdrive.
      09-07-2021, 09:59 AM   #7
mikeojibwa
As for the brand recommendation I would go for Michelin. Primacy 4 is especially well rounded if you do not have racing inclinations.
      12-23-2022, 07:15 PM   #8
ducanjack
Drives: 2010 Nissan X-Trail
Bridgestone Turanza T005 and Michelin Primacy MXV4 have excellent traction control, wet road handling, and a high braking rate. The Bridgestone Turanza T005 is a tire designed to offer a quiet ride. It is made to reduce both exterior and interior noise. The Michelin primacy 4 also can reduce exterior noise, but it could do better at reducing interior noise. Besides that, The Michelin Primacy 4 has a much better damp handling rating than the Turanza T005 at 89% vs. 77%, respectively, and a better cornering rating at 85% vs. 83%, respectively.
      12-31-2022, 08:18 AM   #9
Hellboy550i
Drives: BMW 550i
What abt firestone firehawk Indy 500? Am hearing good reviews abt it ..
      01-26-2023, 04:55 PM   #10
pietrasnet
Drives: BMW 6gt
I recommend the Michelin Primacy 4. I can confirm based on use that they are very good on wet road.
