2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum Euro spec F10, trunk opens with fob, not switch
      02-24-2016, 09:33 AM   #1
manilae90
Drives: 2017 520d G30
2006 320i  [0.00]
My 2012 520d's trunk won't open by the switch near the license plate but will open using the key fob and inside switch. The euro does not have a valet switch and key hole so I'm out of ideas. I was thinking a fuse but since the fob works, its unlikely. Any ideas
      02-24-2016, 06:56 PM   #2
EL Jeffe 5
EL Jeffe 5's Avatar
Drives: CBR1000RR
Don't you have lock button inside glove compartment?
      02-25-2016, 09:09 AM   #3
martin mustang
Ireland
257
Drives: 640d,X5 45e, 911c4s, 635csi
What setup do you have for door locks, if first click to open only driver’s door, and a 2nd one for all other doors, this will also apply for the trunk, i.e. need to unlock all doors 1st before you can use the switch.
Annoying for sure as I only click my key fob twice when passengers with me so always on mode 1 only driver’s door open and often I am just using the key fob for the trunk rather than unlock all doors.
Of course you can change the setup on the i-drive to unlock all doors including the trunk with one click.
      02-25-2016, 11:58 AM   #4
manilae90
2006 320i  [0.00]
Euro cars don't have the valet switch inside the car so no glove box switch. Im also set up to open all doors on one press on I-drive. I'm beginning to think thats its a switch or actuator problem.
Anybody know if the trunk has a double lock or something?
      02-25-2016, 12:18 PM   #5
snj1013
Drives: 2011 528i
Are you trying to open with all of the doors unlocked? All doors need to be unlocked before the actuator at the license plate does anything.
      02-25-2016, 01:45 PM   #6
martin mustang
Ireland
257
By Valet do you mean the switch to open the boot from the inside, if the case I am afraid you wrong most of my cars had it including my last BMW's, as well as the glove box setup.
QUOTE=manilae90;19458223]Euro cars don't have the valet switch inside the car so no glove box switch. Im also set up to open all doors on one press on I-drive. I'm beginning to think thats its a switch or actuator problem.
Anybody know if the trunk has a double lock or something?[/QUOTE]
      02-25-2016, 08:01 PM   #7
manilae90
2006 320i  [0.00]
The valet switch is the one that locks the trunk from the inside. I think located in the centre console. I do have the switch near the footwell and that works. Only the button on the trunk itself is dead
      02-26-2016, 02:00 AM   #8
manilae90
2006 320i  [0.00]
Sucked it up and decided to open the trunk cover. Just in case anyone encounters this problem, heres how I fixed it. The switch or trunk button is enclosed inside a rubber cover. The rubber cover developed a small tear and because of the tear, it is no longer giving the switch tension to activate the trigger. Put some Power Glue / Krazy Glue and duct tape on the inside and the switch works once again
