2010 2011 BMW 5 Series Forum F10 Double sided tape for Carbon Fiber rear spoiler |
11-09-2015, 08:29 PM | #1 |
Rep 72
I am thinking of purchasing the spoiler and putting it on myself.
It is often recommended to use adhesive such as: BMW Betalink Body Panel Adhesive - Genuine BMW 82699408866 Part #: BMW-82699408866 I am more comfortable in using 2-sided tapes instead - seems less messy and easier to me. Any recommendation? Is this any good: 3M Scotch 06376 Automotive Attachment Tape? Or am I better off seeking professional help for installation. Thanks. |
11-09-2015, 10:12 PM | #3 |
Rep 14,522
I ended up getting some 3m tape at Lowe's that was about 1/2" wide cause the 1/4" wasn't holding well. I used it for my front spoiler and redid my trunk spoiler.
11-10-2015, 02:59 AM | #4 |
ZEROdoubleZERO
228
Rep 659
I used 3m scotch 30lb double sided tape to install my trunk spoiler and I'm able to easily remove it if it gets damaged of faded. If you use beta link your pretty much stuck with not being able to remove your spoiler if you need to. In case your wondering how to easily remove taped on parts, just get some wax dental floss and double it up, slip it under the part and use the dental flaus like saw and cut thru it. It won't scratch your paint and works Like a champ! I did it twice when putting on my spoiler, I have OCD it was off center like 1 millimeter the first 2 times!
11-10-2015, 12:54 PM | #6 | |
Rep 554
11-10-2015, 03:26 PM | #8 |
Rep 14,522
11-10-2015, 10:07 PM | #9 |
Rep 72
Guys, any clarification of which kind of 3M Scotch Tape?
There are quite a few choices at Amazon. 3M Scotch 1/2-Inch by 36-Yard Double-Sided Foam Tape - it has "Urethane Foam" 3M 03614 Scotch-Mount 1/2" x 15' Molding Tape - "no foam" |
11-14-2015, 05:14 AM | #10 | |
ZEROdoubleZERO
228
Rep 659
http://www.homedepot.com/p/3M-Scotch...G-DC/205507375 |
11-14-2015, 09:29 AM | #11 |
Rep 14,522
This is what used Scotch Extreme
http://m.lowes.com/pd/Scotch-1-in-W-...d-Tape/3690666
11-14-2015, 08:08 PM | #13 |
Rep 14,522
03-21-2016, 10:03 PM | #15 |
Rep 81
I recently installed my CF rear Spoiler (M Performance) using 3M and for some reason using single tape are not enough to touch the surface of the trunk. I just took it off and put a 2nd layer of double tape which seems to be better but i haven't try to re-install it.
I don't like the idea of using Betalink since it will be permanent but if this is the only option then i would most likely go this route but will have the dealer to install it for me. |
03-22-2016, 08:36 AM | #16 |
Rep 1,161
what happens if you remove a CF spoiler attached with betalink or epoxy?
will it completely damage the paintwork when you take it off?
2014 M5
1990 E30 318i Touring 1999 E38 728i -sold M235i - sold Activehybrid 5 - sold |
03-22-2016, 10:42 PM | #17 |
USAF Pararescue Veteran
332
Rep 770
Yes, I used Betalink to attach the spoiler to my old 530. The spoiler got damaged and I had to remove it, it came up with chunks of paint. I would never use Betalink or epoxy again. 3M automotive double sided tape is the way to go.
03-23-2016, 07:31 AM | #18 |
Rep 14,522
i only thought about going with Beta because i really wanted a tight flush fitment when i install my 3d carbon spoiler coming in but i heard once it's on...it's on! cause i know when i use the 3m double sided tape there is just a minor gap in between...i wonder if anyone has used some kind of filler like black silicon or something to fill that minor void?
03-23-2016, 07:53 AM | #19 |
Rep 687
i just got mine last week and its still only hovering in the 50s and 40s here well 7- 10 Celcius.
I put it on but want to re do it. i'm guessing i put it on too cold and the edges didn't stick as well. going to redo it. I guess i should wait for it warm up for the 3m tape? |
03-23-2016, 08:18 AM | #20 | |
Rep 14,522
03-23-2016, 08:20 AM | #21 |
Rep 687
03-23-2016, 08:24 AM | #22 |
Rep 14,522
I can wait...i think you think it's safe to use rubbing alcohol to clean just the area the spoiler will be mounted to? i know it's got wax among other surface stuff
