07-23-2010, 07:18 PM | #1 |
Rep 145
Daytime Running Lights
I have the DTR lights option ticked on the idrive settings menu, but the lights don't come on when the light knob is in the 0 position, which is what should happen according to the manual. Can anyone shed any light on this issue?...no pun intended.
07-25-2010, 02:09 AM | #3 |
Rep 61
Mine are on when on 0
07-26-2010, 09:30 AM | #7 | |
Rep 73
Funny thing... I noticed that the rear lights comes on too, at night, along with the DRL (or is this part of the "welcome" light?) can't remember if the car was running or in acc mode. Many features overlap so it's hard to tell which is activated individually or along with other. Don't have the time to test nowadays... too busy. |
07-26-2010, 07:05 PM | #8 | |
Rep 145
01-11-2011, 09:07 PM | #10 |
Rep 81
DRL is powered by LED and the headlight is powered by bi-xenon. That's why when you 1st turn on the headlight, its kinda white color but slowly it will turn into yellowish again.
01-12-2011, 09:46 AM | #11 |
Rep 298
not sure when my car was built (think it was Nov/Dec 2010) but I tested this today and found the desired setup I wanted for winter driving as follows (i have the visibility pack):
- ignition off - turn headlight master switch to "A" - in i-drive toggle "daytime running lights" to ON i.e check the box with this combination I get the following behaviour: - daylight driving, angel eye's, rear lights on. - lowlight conditions or driving through tunnel/under flyover or M'way bridge, low beams activate. Low beams deactivate once back into daylight - night time conditions, low beams automatically on this behaviour is exactly what I wanted....seems to contradict what i'd read in other threads so not sure if the s/w on the headlight modules has been changed or if the light sensor is set differently on recent builds but for me it works how i expected it work with these settings. |
01-12-2011, 01:54 PM | #12 |
Rep 14
If you have the standard Halogen lights (UK) then the only way to get Angel Eyes on in isolation is to set your lights to 'side lights'. If you're expecting Angel Eyes only with DRL ticked and lights set to Auto then you're going to be disappointed (as I was), as this also illuminates dipped beam.
01-12-2011, 02:41 PM | #13 |
Rep 298
Alan48 makes a good point, I should have clarified in the UK the visibility pack basically = Xenon's, high beam assist, adaptive headlights and headlamp wash. but its not a standard pack in the UK its extra.
so it sounds like the behaviour is different depending on lights you have and/or maybe the build date which i guess could affect things like software versions on the light modules/controllers. |
01-13-2011, 06:06 AM | #14 |
Rep 4
Currently, If the light switch is in position 0, i.e off and DRL's are selected, I get NO lights. This is different to what the manual states.
Can anyone confirm this is correct, as the dealer does not seem to know. Thanks |
01-13-2011, 06:36 AM | #15 |
Rep 298
you got xenon or halogen? seems to be differences in way two work. xenon's on mine and i get DRL (angel eyes) if DRL on in i-drive and switch set to "A". will check later what happens if switch is "0"
01-13-2011, 07:23 AM | #16 |
Rep 186
We discussed the same or similar matter in here...
http://f10.5post.com/forums/showthread.php?t=441638 Hope this helps !
2013 - x30d E70 M Sport
2010 - 520d F10 SE |
01-13-2011, 08:30 AM | #17 |
Rep 145
This was the problem with my car. The light won't switch on "0" position when the DLR option is ticked on idrive. According to the manual, it should switch on. I've taken the car to the dealer. They had the car for a day and finally said they have send my software to HQ and is awaiting advice from them. This was over a month ago. Still no reply
01-13-2011, 04:39 PM | #18 |
Rep 4
Had an email back from my dealer today saying they'd heard back from BMW, which said there was no fault it's meant to be like that.......anyway, still waiting back to hear from another route into BMW, so who knows.
Thanks for the reply, if I hear anything else back I'll let ya know |
01-14-2011, 03:44 AM | #19 | |
1989
Rep 9,498
It would be logical to carry this trend on to the F10 series!!.
2021 LCI M5 Marina Bay Blue/ Smoked White Leather |
09-05-2011, 03:11 PM | #20 |
Rep 186
Little old topic, many of you may have discovered the UK story on DRL.
I had my car to 2 dealerships in Scotland and both had it in the analyser to check the lights. Nothing was wrong on DRL or anything to do with lights. Conclusion is; If you have Xenon you will have the Angel Eyes (rings) on as your DRL. But if you have the standard Halogen (like me) you won't get only the angel eyes on, but you will have the dipped headlights on as well. I was told this is because the Xenons are powerful than the Halogens and it's why they worked like that :|
09-05-2011, 04:24 PM | #21 |
Rep 371
I'm sure the owner manual in iDrive tells me that Halogen lights means DRL = dipped.
If you want to preserve your bulbs, twizzle the switch to side lights.
Had: E91 320d ES Titanium Silver
Now: F10 520d SE Alpine White, Cinnamon Brown leather, Business speakers |
