2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum Daytime Running Lights
      08-08-2013, 01:45 AM   #45
kthankzbye
kthankzbye's Avatar
86
Drives: 2011 F10 550i, 2020 G05 40i
My friend got his LED angels coded that it's 2x brighter...
Bad thing is they are 2x brighter when his xenons are on and regular without the xenons on.
I'll try to make a comparo picture with his coded LED and mine. His is blinding...
      08-08-2013, 09:58 AM   #46
Mr. Grumpy
BMW Enthusiast
Mr. Grumpy's Avatar
Drives: 2022 X5
I don't like how the LED's dim when you turn the Xenons on. Can your friend give you the code for this, I've been looking for it for a while.
2022 X5 sDrive 40i Carbon Black | Ivory White Vernasca Leather | Aluminum Tetragon Trim | ZMP | ZPP | ZLS | ZPK | 337 | 4NB | 3M2 | 4HB | 7M9 | Black Kidney Grills |
      08-09-2013, 07:24 PM   #47
GIANITALY
GIANITALY's Avatar
Spain
38
Drives: 2016 X6 M/MPPK
  [0.00]
+1 . should be always on bright with low beams.
2016 X6 M PACK/MPPK
RACECHIP BLACK GTS
RACECHIP XLR
      08-10-2013, 10:35 AM   #48
Hoa
the reason why it dim down is because when you drive, the on coming traffic will think you have your high beam on and flash their high beam at you. when in the dark, less light is needed to see the rings as well
      03-22-2016, 09:10 AM   #49
harshawij
Drives: BMW 523i 2010
Originally Posted by gspannu View Post
The DRL lights behaviour on F10 can be coded.
If you have halogens and only want your 'Angel Eyes' to turn on when DRL is checked; it is possible.
You can code your car and choose from various options:
a) Angel Only
b) Angel with Rear
c) Angel with Halogen (which most people have)
d) etc..
A similar set is also available with Xenons.
I have recently programmed both in 2 different cars. My own car is Xenon and I changed some of the behaviour.
The other car was halogen and he had Angels+Low Beam and we converted this to Angels only.
So, in a nutshell; definitely possible via coding using E-Sys.
Hi gpnannu,
Can you please let me know which code to use to just get the Day time running lights without the Hanlogens ?
Thank you.
