2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes tires problem
      02-11-2014, 08:58 PM   #1
slownfast
Drives: 2013 528i Xdrive
tires problem
I just changed the wheels recently to aftermarket and it comes with the tires. I bought it from this forum. the tire spec are 245/35/20 (front) and 285/30/20 (rear). The problem is that it makes sound inside the cabin above 25 mph like swinging around. is that because of the tires? I know that the tires brand are not reputable, it is lion hart. it was a good deal though, so I cannot reject it.
Do I need to replace the tires to hankok v12 to get rid of the sound?
I am going to upload the video clip when the road is not crowded anymore.
      02-11-2014, 10:05 PM   #2
EV0LVE
EV0LVE's Avatar
42
Drives: F10 535i SG
Start by getting it road force balanced. Then properly torque the lug bolts. Make sure the bolts are long enough.
Good luck!
      02-11-2014, 10:27 PM   #3
slownfast
Good luck!
I don't use any spacer though, do I need to use longer lug bolts?
      02-11-2014, 10:48 PM   #4
Dan1416
Dan1416's Avatar
39
Drives: 2013 528 x-drive
Good luck!
Lugs shouldn't be the problem if you didn't use a spacer. Just have them road force balanced and torqued to correct specs. Are the tires directional? If they are and are on wrong you will get that humming noise. Any vibration?
      02-11-2014, 11:28 PM   #5
slownfast
Good luck!
So i should ask them to get it checked again if it is directional or not. It makes humming noise and a little bit vibration. However, the vibration is really a little.
      02-12-2014, 05:20 PM   #6
slownfast
Hey guys, just asking. Could it be wheel bearing? I never got that problem before i changed it to aftermarket wheels.
      02-12-2014, 06:03 PM   #7
Dan1416
Dan1416's Avatar
39
Could be but I doubt it. If it never happened before then it sounds more like something caused by your new setup. It would have to be an extreme coincidence that the bearing went bad at the same time you mounted your new wheels
      02-12-2014, 06:35 PM   #8
slownfast
I think it is because of the tires. What should i change to get rid of the sound?
      02-12-2014, 08:57 PM   #9
Dan1416
Dan1416's Avatar
39
Have you checked to see if they are directional?
      02-12-2014, 10:06 PM   #10
slownfast
they said that those are already directional.
      02-13-2014, 09:31 AM   #11
Dan1416
Dan1416's Avatar
39
Next step would be to have them road force balanced
