2010 2011 BMW 5 Series Forum F10 Help!::Bavsound/Bimmertech setup Vs HK setup |
09-01-2016, 09:39 PM | #1 |
Rep 57
So, I've driven a 235m and 435i and they both had the HK speaker system. Both sounded pretty good and I could really turn the volume up and i heard no distortion.
Now, I currently own a 535d with upgraded bavsound speakers, bavsound underseat woofers, and the bimmertech amp. Yes, the sound is more clear with this set up but I always...ALWAYS hear distortion if i turn up the volume. Now, bavsound told me its my files (same files played in the other two systems was fine) bimmertech told me that they don't have a tune for the 5 series as of early this year. All this is understandable but will my setup always have some type of distortion at higher volumes? I'm not saying its so high that my ears are hurting. I could get up really loud in the HK system where it was uncomfortable but not with my system. Bimmertech told me i could flip two switches on my bimmertech amp to get the music louder. Maybe thats the issue? Does anyone with a similar setup have a similar problem? If so, is it the speakers? the amp? or both?! Thanks a bunch in advance. This problem has been going on for like 9 months and I'm just not as satisfied as I feel like I should be. |
09-02-2016, 10:02 AM | #2 |
Rep 14,521
Have you not hooked up your labtop to make the needed minor adjustments? Sounds liked you hooked everything up but never tuned it?
09-03-2016, 02:35 AM | #4 |
Rep 135
You got to know how to tune it! The tune that's come with don't sound as good as if you know how to tune it. The Bavaudio tune cut a lot of bass & mid's. You need a old pc lab top & do a tune!
09-03-2016, 08:33 AM | #5 | |
Rep 14,521
exactly. i know Nelson will preset a file for the Bav's but a lot of times it won't sound the same in your car? not sure why that is but that's why you still have to go in and tweak according to your setup and what sounds good to you. what sounds perfect for me may not sound good to you when i built my system in my Titan it took a pretty good hour just going back and forth on what sounds perfect for me. a lot of adjustments on gain control from front to rear speakers. setting the crossover points. setting the crossover points for your lower frequencies to your subs. also setting the gain controls for your lower freq. so you have to keep tweaking and adjusting until you hit the sweet spot. nothing's plug n play.
09-03-2016, 08:41 AM | #6 | |
Rep 14,521
here you go! here's a fellow member who just went through a similar process as you did!:
09-12-2016, 08:32 PM | #7 |
Rep 57
So, i took an audio sample of the distortion. At second 25,26, 27 you can hear the distortion. Is this the amp overpowering the subs??
Thanks for your help in advance! I will get my work laptop to show you what my eq settings are on hopefully tomorrow. |
09-13-2016, 07:10 AM | #9 |
Rep 57
Delje...did you flip any of the pin settings on the actual amp?
Also, for a guy that doesnt know how to tune. What parameters should i be messing with to get rid of that crappy noise? |
10-11-2016, 07:55 PM | #10 |
Rep 8,364
I would not my speakers sounding like that either. How do you have you Equalizer, Base/Treble, & Balance/Fader Setup?
