2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum F10 Pre LCI Reverse Camera Retrofit wiring diagram
      03-12-2019, 07:57 AM   #1
deltacossigma
Drives: BMW 520d
Hi All,
After successfully retrofitting 2TB I have finally gathered the courage to take one step further and retrofit the reversing camera 3AG.
I have source most of the hardware but am struggling to find the wiring diagrams (still need to buy the wiring)
I have seen an F30 OEM retrofit guide but haven't been able to find the F10 OEM retrofit guide.
Can anyone help? or Can someone pull some wiring info from ISTA please? I cant seem to be able to find a ISATA link either.
Any help is much appreciated.
      03-12-2019, 04:53 PM   #2
wcr3d
Drives: 2013 535i XDrive M Sport
Try here.
www.newtis.info
      03-12-2019, 07:17 PM   #3
deltacossigma
Drives: BMW 520d
Smile
Originally Posted by wcr3d View Post
Try here.
www.newtis.info
This is soooooo awesome. Thank you very much.
      03-12-2019, 07:34 PM   #4
wcr3d
You're welcome.
Another site to mark. Very good for part numbers.
www.realoem.com
      03-13-2019, 01:42 PM   #5
deltacossigma
Drives: BMW 520d
You're welcome.
www.realoem.com
Yes that is very good one indeed. I used to confirm all the hardware that I bought..
Thanks to your previous suggestion. I just confirmed all the required cables and have placed the order. Should be here in a week.
Do you have any idea about the retrofit.. Do I just need to VO code the 3AG ?
Found another forum which seems to have some very good info but the original poster was running into some errors as well (not sure if I am allowed to post links to other forums??)
      03-13-2019, 02:19 PM   #6
n3985
Drives: a car
If you are doing a full OEM retrofit please document your process, part numbers, coding needed, will be good resource for anyone else looking.
      03-13-2019, 04:41 PM   #7
wcr3d
That is something i don't know.
There is a coding sub forum for that type of information.
      03-14-2019, 05:30 PM   #8
deltacossigma
Drives: BMW 520d
Will definitely try my best. Though I am not very disciplined when it comes to documenting but I think this retrofit can do with one
      03-14-2019, 05:31 PM   #9
deltacossigma
Drives: BMW 520d
      03-22-2019, 07:53 AM   #10
deltacossigma
Drives: BMW 520d
Received the cables. if weather permits, I should be able to make some progress with the install this weekend.
BMW F10 520d
Retrofits:
2TB -> Complete with gear stick, paddles and DEC switch.
Tags
3ag, f10, reverse camera
