2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum vibration
      09-21-2012, 10:03 PM   #1
ajandhek
Drives: none
vibration
to make a long story short I had my rim bent by a pothole (rear passenger)..I got the rim fixed by a professional prolly the best around..then I got all the wheels rebalanced and was told the wheels balanced fine with no hops..but I still feel a vibration at 60mph And up..anyone know what it can
be it's drivin me nuts!!
      09-21-2012, 10:23 PM   #2
snj1013
Drives: 2011 528i
Not too tough to figured out, either the wheel is still not true, or your rebalance wasn't done well. Find a shop that has a Hunter Road Force balancer and see if they can determine if the fixed wheel is the problem, or if you are out of balance.
      09-21-2012, 10:33 PM   #3
ajandhek
Drives: none
I got the rim that was bent road force balanced an it came out perfectly normal..should I get the other 3 road force balanced?
      09-21-2012, 10:56 PM   #4
snj1013
Drives: 2011 528i
I would. Are you sure the front passenger wheel isn't bent as well. Hard to hit a pothole with just one wheel.
      09-21-2012, 11:02 PM   #5
ajandhek
Drives: none
well the thing is the front tire was hit first which resulted a bubble on the sidewall..replaced the tire then or a regular balance and were no hops during the balance
      09-22-2012, 07:20 AM   #6
snj1013
Drives: 2011 528i
Road force them all and I'm sure you will find the problem.
