2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications Drive Train Malfunction over half throttle
      03-15-2017, 05:26 PM   #1
DigitalNav
Drives: 2013 535i M Sport
Car drives absolutely fine. If you give it more than half throttle to the point where it drops a gear to accelerate, it throws a drive train malfunction. no CEL or codes.
Any idea?
2013 F10 535i M-Sport
Alpine White
Oyster/Black
OEM M5 Exhaust with Resonator Delete
      03-15-2017, 07:23 PM   #2
STR8-6IX
Drives: RWD 528i N52
Any idea?
I get this issue when revving at 5000RPM+
more prone to happen during cold weather. I can redline it in the higher gears, but taking off aggressively in first gear for example causes the light to go on as soon as i upshift.
when you restart the car, does it run fine, and does the CEL remain on?
it could be so many different things. most likely spark plugs or coil packs which is what i am suspected for my car. what mileage are you at? you will need to get your car scanned to find out.
      03-16-2017, 09:25 AM   #3
SLVSRFR
SLVSRFR's Avatar
Guam
245
Drives: BMW 550i
This. It can also be injectors. That's where I would start first, but since you have no CEL it would be hard to diagnose. I would take it somewhere that can do the proper tests, or download Rheingold and start from there
STR8-6IX536.00
      03-16-2017, 09:45 AM   #4
FSociety
IG @bmwF9xG80
FSociety's Avatar
3813
Drives: G80 M3, X4M, G07 X7m50
2023 BMW G80 M3  [0.00]
2020 BMW X4MC  [0.00]
16' BMW X4 M40i  [10.00]
06 Cadillac STS  [0.00]
+1 Rheingold
60-130mph 6.5s X4M #HCP
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce
IG: @bmwF9XG80
      03-19-2017, 01:36 PM   #5
AWF87M2
AWF87M2's Avatar
827
I would buy a couple bottles of BMW fuel system cleaner plus by Techron. I started pouring a bottle in the gas tank every 2k miles starting from 30k and it made a huge difference. It does a good job at cleaning the carbon build up including the residue on the injectors.
      03-19-2017, 02:21 PM   #6
DigitalNav
Turned out its a boost leak, the next step is finding where exactly the leak is happening.
Alpine White
Oyster/Black
      03-19-2017, 08:39 PM   #7
vivanapoli806
Drives: 2012 535i Xdrive Msport
I would recommend running an aftermarket charge pipe if you're not doing so already.
      03-19-2017, 09:28 PM   #8
DigitalNav
Yeah I've had a ER charge pipe on the car for like 4 months now. I think something got knocked loose after the DME was taken out to unlock.
Alpine White
Oyster/Black
      03-19-2017, 11:18 PM   #9
SLVSRFR
SLVSRFR's Avatar
Guam
245
Drives: BMW 550i
Is your car throwing a CEL now? If you have a big boost leak (should be if you're throwing DTM's) it should be accompanied by a CEL with the 30FF code. How did you determine it's a boost leak?
      03-20-2017, 01:26 AM   #10
DigitalNav
no CEL, likely due to the flash tune.
Determined its a boost leak from PTF, guys who make Bootmod3. Sent them a log file. You also dont hear the blow off valve anymore when you let off the gas
Alpine White
Oyster/Black
      03-20-2017, 01:59 AM   #11
SLVSRFR
SLVSRFR's Avatar
Guam
245
Drives: BMW 550i
Ok, makes sense.
      03-20-2017, 09:24 AM   #12
FSociety
IG @bmwF9xG80
FSociety's Avatar
3813
AWF87M2 I use E85 for cleaning and 1-200 miles before oil change the Techron stuff (since I bought a pack at Costco for dirt cheap)
DigitalNav Rheingold will help you tremendously to find any errors/issues with the car. When I Unlocked my car, the mechanic himself forgot to tighten 2 sensors and I had some funky codes (no CEL) ; not related to the tune or anything. Went back to the shop, mechanic used Rheingold and found the sensors he had to push in.
Your BoostLeak could be anywhere near the Throttle Body or Charge Pipe since they have to unplug that to reach the ECU
IG: @bmwF9XG80
      03-20-2017, 01:08 PM   #13
DigitalNav
Thanks for all the help guys! Car feels so much faster with BM3... just need to fix this boost leak and properly enjoy.
Alpine White
Oyster/Black
      03-20-2017, 05:50 PM   #14
vivanapoli806
Any plans to get on a dyno jet and compare this with Missions stage 1 tune ?? Are you just running an ots map ?
FSociety3812.50
      03-20-2017, 06:32 PM   #15
DigitalNav
Dont wanna pay for another dyno run right now as it doesnt matter to me. Unless someone else wants to pay for it haha. Ill dyno it once i get more mods + stage 2.
Alpine White
Oyster/Black
      03-20-2017, 07:19 PM   #16
vivanapoli806
lol I hear you. I literally see zero info about gains or numbers with bootmod3 for our n55's. I have an authorized dealer not far from me in Chicago. That's the only thing making me lean towards this direction and not do Mission Performance.
      03-20-2017, 08:49 PM   #17
DigitalNav
Both routes aren't bad. Im in NorCal and had an authorized BM3 open up next to me and heard good things about it. I also like the ability to flash myself and log. Overall i think its a better end-user experience.
Car feels like night and day difference... debating on installind a downpipe and a FMIC to go stage 2.
Alpine White
Oyster/Black
      03-20-2017, 09:01 PM   #18
FSociety
IG @bmwF9xG80
FSociety's Avatar
3813
vivanapoli806 what are the Mission Stage1 numbers?
DigitalNav If I were u, this is what I did..
Talk with your preferred Dynojet shop (RWD is cheaper than AWD usually) get a few friends from the boards if you want. Set up a Group Dyno or rent the dyno lets say $125 first hr and $60 after (for ex.)
I went to do 4 pulls, 3 with piggyback and last one I put it on map0 to serve as a baseline pull. (93 octane)
I went back 2 months later, with e35% mix and did the same some 4th gear pulls and 5th gear pulls with piggyback maps and then last one map0.
Now that I added FMIC/DP + BM3, I'll go back with 93 octane and do 3 pulls, and flash back to stock do a baseline pull to see what is the delta of that day with the mods. I'll add 30% e85 and do 2 pulls on baseline, flash to Stg2 map and/or E30 map if i have one by then for about 3 more pulls.
Unless you have a drag-strip u can visit weekly then i'll just go to Dyno right now to see what delta or differnece you will gain from your next stage.
FMIC will help with Heatsoak more consistent power back to back pulls (dyno proven) and logs you will see IAT temps not skyrocketting as much (I just did my fmic 2 weeks ago) after a year, def will do this asap on my next car but i waited for the right one. CTS Turbo brand was tested on another X3 35i he had the shop do a little mod to it and comparing to others it was the easiest one (shop said) where i read.
IG: @bmwF9XG80
      03-20-2017, 09:18 PM   #19
vivanapoli806
@FSociety The numbers for their stage 1 tune posted on their website is 318/436. I'm going to send ptf an email and see what their claims are. My local bootmod3 dealer said they don't know of any f10 n55 running this yet.
      03-20-2017, 09:25 PM   #20
DigitalNav
FSociety how soon are you planning on dyno the FMIC and Downpipe?
Did PTF say anything to you about running a e85 blend? They said they dont recommend on stock HPFP.
Alpine White
Oyster/Black
