04-14-2019, 05:31 PM | #1 |
Rep 64
Controll Arm??
I'm running an aggressive setup with 9 wide in the front and 10.5 in the back. today while looking at my wheels I noticed my upper control arm is close to my tire. I'm running a +20 in the front so the offset is low to be out of the way as much as possible. If I drop the car am I going to run into rubbing issues with the front control arms?
Thanks for your help! |
04-14-2019, 05:53 PM | #2 |
Rep 14,521
I'm running 21x11 38mm rears with 295's with plenty of clearance from any suspension components. For the fronts 21x9.5 30mm with 255's with no issues. Sounds like your offsets for the fronts could be an issue. Can you take a picture?
EDIT: wait, I remember your car now. Front looked fine. Maybe a tad poke but you should be fine me thinks?
~F90Conversion~21"3Piece Forged AvantGardeWheels~KWV1Coilovers~CQUENCE slotted/drilled rotors~GoodridgeStainlesslines~MeisterschaftQuadEx haust~Akrapovic 4"tips~VRSF DP~VRSF CP~TurboSmart BOV~K&N filter~CarbonFiberExteriorComponents~GladenAlphaCo mponents~MatchUp7BMW~Punch P300-12T~ Follow me on Instagram: lsturbointeg |
04-14-2019, 06:30 PM | #3 | |
Rep 64
compared to your set I have a teeny tiny bit more pole than you Last edited by Flyguyin23; 04-14-2019 at 06:39 PM.. |
04-15-2019, 06:42 AM | #4 |
Rep 14,521
Your good! Mine looks like yours but probably a tad closer
Flyguyin2345.50 |
04-15-2019, 06:52 AM | #5 |
Rep 64
