2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes Considering moving to a square setup - Need advice.
      02-28-2019, 04:38 PM   #1
Fly335dguy
Drives: 2014 535dx M-Sport
Greetings,
I am considering moving from a staggered setup to a square setup and wanted to ask advice from the group.
Here's what I've got:
535dx m-sport on staggered style 351M 19" x 8.5" Fr & 19" x 9.0" Rr double-spoke wheels with P245/40R19 Fr & P275/35R19 Rr
Looking to move to:
Square setup with either:
8.5Jx20 ET33 or 9Jx20 ET44
Here are my questions:
1. Which rim size and offset is better for xdrive?
2. Which wheel would allow me the largest tire? I was hoping to go with 255/35R20 non-runflats all around.
Goals are to have a good balance of traction, ride quality and handling while being able to maximize tire duration. I also want to fill in the gap in the wheel well and tire.
I plan to upgrade to either ACS springs or KW Var3 coils at some point, so it will be lower a bit.
Thanks!
      03-01-2019, 12:40 PM   #2
remmib
remmib's Avatar
Norway
1569
Drives: 2013 F10 520d M-Sport
Are you considering aftermarket wheels, or only OEM wheels?
      03-01-2019, 02:30 PM   #3
Fly335dguy
Probably just the OEMs but I would be open to anything.
      03-01-2019, 06:00 PM   #4
Flyguyin23
Flyguyin23's Avatar
46
Drives: 15' M sport 528i dark blue
Originally Posted by Fly335dguy View Post
Greetings,
Looking to move to:
Thanks!
On my very long journey of finding the most aggressive setup, I've noticed a few things. unless you are going very low on offset with an 8-9in wide it will require the assistance of spacers to help with fitment (lip to fender look)
as far as x-Drive, the only stipulation was the fronts and rear had to be within 1% of rotating mass. if you're going staggard that would be important but Since you are looking for a square setup that shouldn't be an issue. IMO the wider the better. can't beat more rubber on the road to put more power down or to grip in cornering. can't go wrong with 9 wide. 255 tires would be better paired with a 9 inch wide
      03-03-2019, 01:09 PM   #5
Fly335dguy
Many thanks!
Here's what I'm thinking, 20x9 et 44 all the way around with 255/35/20.
My question is whether or not the fronts will rub with that large of offset. I'm thinking it won't, but wanted to seek advice from others.
I plan to lower to either coils or ACS springs (1-2" drop).
      03-03-2019, 08:25 PM   #6
Flyguyin23
Flyguyin23's Avatar
46
Many thanks!
lsturbointeg has the most aggressive set of offset wide wheels on a NON M5 f10 that ive seen and he doesn't rub with 21× 9.5 et30 in the front.
Remmib is the fitment god on the forums (his fitment is textbook perfect) and he is running 20x9 +26 in the front. I've read no complaints about him from rubbing.
(Between the two is the holy grail of fender to lip flush fitment for non M5 F10 fitment IMO)
I have 21x9+35 on the way and I plan on immediately putting on 10mm spacers on the front. Since your offset isn't as aggressive you should have NO issues with your setup. the only reason for doubt is if you have big brakes on her. If you don't your in the clear. btw different tires have different sidewall beef (like how thick and bulky it is) tires make a difference as well. BUT in your instance, you have plenty of room. Good luck brotha! your setup sounds like a really good tuck fitment great for bags!
      03-03-2019, 10:15 PM   #7
cdmulders
cdmulders's Avatar
Drives: 2013 535xi
Many thanks!
With your proposed setup, I'd be concerned about the wheels or tires rubbing on the suspension on the front. Because your offset is 13mm more than stock, and because you are going with a 9" vice 8.5" wheel, and because you are going with a 255 vice 245 tire, the inside of the front rim & tire will be tucked in even more. The inside of the wheel will be 17.35mm / 0.68" closer to the suspension. The wider tire makes the edge move another 5mm closer too. Before you buy these wheels, I'd measure the current distance between your wheel/tire, and the suspension, and in particular the upper A-arm joint. If it is less that 1", then you may have a problem with your proposed setup.
2010 Z4 35i, Crimson Red, beige interior, 6sp manual, Adapative Suspension
2000 528i, Cosmo Black, beige interior, Sport package (retired)
      03-04-2019, 02:54 PM   #8
Fly335dguy
Thanks, I appreciate that insight. Now it sounds unlikely to do a square setup and will probably stick with standard factory sizes.
      03-04-2019, 04:38 PM   #9
JayBimmer83
Drives: 2016 535i
I have a square setup with 20x9 et 35 all the way around. You could probably put some spacers on the front but it looks ok to me
      03-05-2019, 02:15 PM   #10
remmib
remmib's Avatar
Norway
1569
255/35/20 fits very well on 9'' wide wheels. But ET44 is not a good fitment in the front, and as others have mentioned, I'm not sure it's clears the inside. Of course some spacers will fix that.
      04-25-2019, 06:32 AM   #11
Lukaas54
France
Drives: BMW F10 530d
Hi Jay,
All your wheel are in 9x20 ET35 ? No problèm on the front ? Because the Space between wheel/tyre and suspension are small ~3/4mm no ?
Thanks
Lukas
      04-25-2019, 06:50 AM   #12
JayBimmer83
Drives: 2016 535i
Hi Jay,
Thanks
yep they are all 20x9. And I have no problems with rubbing at all. When they were fitting the wheel without the tire it looked close to the suspension but once the car was on the ground it wasn't as close. I got Niche wheels and I even confirmed with them before I put the tires on. you should be good with 20x9 wheel and a 255x35x20 tires
      05-17-2019, 09:04 PM   #13
Ozzy24
Drives: 2015 BMW 528i Xdrive AWD
Need help please..20inch +40 offset wheels tucked
I just got 20x8.5 ET40 for my 2015 528xi which originally is stocked with 17x8 ET30. The recommended specs for it are 20x8.5 ET33 so it's a 7mm difference in space they're currently tucked and it looks kinda goofy so what size spacers might I need for both front and back? The spacers I saw start at 10mm so maybe go 15mm in the rear and 10mm in the front? I'm not really sure how far I can push it without having problems.
      05-18-2019, 02:17 PM   #14
remmib
remmib's Avatar
Norway
1569
I'd rather go with 12mm in the front.
      05-19-2019, 06:40 PM   #15
Ozzy24
So I ended up getting 12mm for the back and 10mm for the front since the front already kinda sticks out a little further then the back so it's spec'd for 33ET for 20x8.5 so the back will be ET28 and front ET30 so I think I should be good now it'll only stick out a tiny bit but hopefully get the more aggressive look I'm trying to go for versus the goofy looking tucked under which I currently have
