2010 2011 BMW 5 Series Forum F10 Any experience with stoptech BBK for F10 550i? on sale for $1800 |
03-29-2019, 01:39 PM | #1 |
Rep 342
I was looking around today and saw an ad for stoptech BBK for my LCI 550i. I looked at it and it was ~$3400 for the fronts, complete kit. I did some more shopping and found a set on clearance for $1800 in silver or black (probably get the black). I think these are "ST60" 6 piston calipers.
StopTech Big Brake Kit 83.B32.6D00.xx (xx is type of rotors and caliper colors) I am wondering if anyone has this Stoptech kit on an F10? Any issues? Do they seem to provide better stopping performance over stock brakes? 550i is a big car and I would like to improve this... How about maintenance? All I can find is D1247 size for the pads. Does this mean I can use any D1247 pads? How do you change pads on these calipers? Do you have to pull the entire caliper off like the stock calipers? (I had Akebono BBK (stock brakes) on my G37S and it was two pins that slide out and the pads could be swapped from the top without removing the calipers. Super easy maintenance.) Also how about rotors? The kit lists them as 380x35mm (some places like ECS call out 380x32mm for the F10 BBK). Do you replace the entire thing or just the outer disks? Any estimates on cost or where can I find the part numbers to shop for replacement disks? Thanks! Last edited by Luky; 04-14-2019 at 09:53 AM.. |
03-29-2019, 05:38 PM | #2 |
Rep 342
So I contacted John Butler (the business proprietor) at Buybrakes.com as I really wanted Red calipers if I was paying for a BBK. They contacted Stoptech (apparently they are a very large distributor for Stoptech) and I guess they had a "partial" kit and agreed to manufacture another red caliper and provide it for the overstock sale price of $1800. This is like half price! I was able to get an awesome deal and John was great to speak with (another enthusiast). He said they still have one black BBK and one silver BBK for BMW F10 remaining at this sale price if anyone is interested.
Try contacting him through their website buybrakes.com. I just sent a text inquiry to 702-903-1713 to get started. I am not affiliated with them in any way, just thought I would share what seems to be a great deal... (He said the M3 BBK sets all sold out the first day of the sale). I already received the order confirmation email and he said it should be about 3 weeks to complete the kit and ship it. https://www.buybrakes.com/stoptech-brake-kits-sale-on-overstock-big-brake-kits |
03-30-2019, 01:39 AM | #3 | |
Rep 455
I have StopTech rotors. No complaints. They are holding well. |
04-12-2019, 12:27 AM | #4 |
Rep 342
Guess what I got today?
[IMG][/IMG] I have a pair of calipers from a 760Li (same as 550i calipers but with taller caliper carrier to use bigger pads on 374x36mm rotors; this is the euro 550i "high speed brakes" set upI was going to do). They weigh 17.4lbs each vs the Stoptech calipers at 10.2 lbs each (with bracket). Will have to wait until I pull the stock rotors to see the weight difference there. [IMG][/IMG] [IMG][/IMG] Last edited by Luky; 04-12-2019 at 12:38 AM.. |
windowmaker70.00 lsturbointeg9158.50 |
04-12-2019, 09:37 AM | #5 |
Rep 377
Drives: 16 X3 28d/18 540d xdrive
What a nice looking setup and not that expensive considering you're getting an entire kit (caliper, rotor and pads) that actually fit the car. Assuming that the caliper is aluminum, it will be much lighter than the stock setup. I recently changed pads and rotors on my 535d and was amazed at how heavy the stock front caliper and forged carrier seem to be. It was difficult holding the caliper (with one hand) while securing it a suspension part before removing the carrier. Hopefully, we'll see photos of the end result soonest. BTW, are existing brake line compatible with new calipers and will the kit require new, larger wheels due clearance issues?
04-12-2019, 11:59 AM | #6 |
Rep 342
It came with new Stainless braided lines for the front. From what I could find (templates) from the same caliper /rotor kit on E60 and E60 M5 it should fit my 19" stock wheels ok. The calipers are so much smaller I dont expect an issue but will bolt one in and test fit a wheel before I start removing brake lines...
I always use a short ~12" bungee to hang the calipers from the spring. Just rest it on top of the rotor/strut while doing the bungee. |
04-12-2019, 02:27 PM | #7 |
Rep 377
I looked at the suggested website and found your brake kit. In looking at the list of BMW's intended for the kit, it mention a 535d but no 535d xdrive. As my brake pads and rotors and calipers appear the same as those of a 535i xdrive, I am assuming my car was mistakenly omitted from the list. Nevertheless, you got a great close-out deal relative to the list price. Also, with this kit available, why would anyone fool with Russian adapters and M5 calipers? The Stop Tech's seem every bit as good. BTW, once you've completed the installation, could you estimate if the new calipers would clear 17 or 18 inch rims as well as the 19's. Buying new wheels and tires, in addition to the brake kit can be expensive.
04-14-2019, 03:40 PM | #11 |
Rep 377
What happens to the OE front brake wear sensor? Did you just unplug it?
04-14-2019, 05:55 PM | #12 |
Rep 342
The stoptech install instructions basically say to unplug it, clip it a few inches from the plug, strip the wires, twist together, solder, and cover with heat shrink. Plug back in. This will keep you from seeing a brake sensor error. Worked fine for me. (Used an old sensor wire that came in the 760Li calipers I bought.)
04-14-2019, 07:26 PM | #13 |
Rep 342
04-15-2019, 01:32 PM | #15 |
Rep 377
Relative to the performance of the OE brakes, how do you rate the StopTechs?
04-15-2019, 01:48 PM | #16 |
Rep 342
They will certainly stop you quick! My butt dyno says they are better. Have not really gotten on them other than bedding and did not do a "before" 60-0 on my draggy. I did the bedding in process twice per instructions (10 runs from 60mph-10mph, 80% braking) allowing it to cool overnight before doing again. Rotors look good, i.e. grey surface from pad compound. Pads are pretty dirty so far on par with stock BMW pads... debating on doing a satin black plasti-dip on my wheels to see if I like the dark color and how it might hide brake dust...
04-16-2019, 07:05 PM | #17 |
Rep 14,521
Looks AWESOME!
