04-22-2019, 11:11 AM | #1 |
Rep 13
Shifted front subframe
Hello guys,
Long story short, My front subframe shifted to the left 0.14- degrees (setback). The left front wheel now sticks out when looking from behind as if the car dog tracks. Did a chassis inspection which came back normal and now my question is how much should I expect to pay to shift the subframe back into its place ? An estimate would be much appreciated Bmw 530i 2013 Alingment - Fine except the front setback Chassis - 100% fine when the car got mounted on a frame machine. Tires - replaced all tires 3 months ago Front lower control arms - replaced 5 months ago This problem started around 8-9 months ago. Thanks for reading |
04-23-2019, 07:07 AM | #2 |
Rep 5,691
The subframe sets onto pins in the frame... so it can’t shift. Did you hit something? Did you bend something?
04-24-2019, 07:29 AM | #3 |
Rep 13
Was told the pins got a bit loose and the subframe shifted left a bit. Now I need to replace those pins and mount the subframe back into its place. I did hit a pot hole 10 months ago and it was pretty bad
