2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes Need help on wheel specs...
      04-23-2019, 06:47 PM   #1
neverdone
Drives: X5, 335, Ford Lightning, 63 me
Thinking about a set of wheels and I cant seem to search up similar fitments. I have an Xdrive, the setup already has tires.
FRONTS: 19x9 +35 245 / 35 R19
REARS: 19x10.5 +32 275 / 30 R19
I'm not lowered right now, but I will be eventually. I seem to see 19x11 with mid 40s offset, so i dont see there being an issue with a +32, but still unsure. What do you guys think? Tires good for the xdrive?
      04-23-2019, 07:07 PM   #2
Flyguyin23
Flyguyin23's Avatar
46
Drives: 15' M sport 528i dark blue
245/35/19 and 285/30/19 is the holy pair. the diameter difference is the closest you can get at 0.08% without going square. if you went with 275/30/19 and the 245/35/19 is a 1.00% difference. which for x drive is the max. as far as fitment the back will be on point and the front will tuck a bit some good quality spacers will push them out no issues.
I run 21x10.5 +30 in the back with 285/30/21 and 21x9 +20 with 245/35/21 in the front. . Ill attach some photos so you can see the fitment im refering to.
      04-23-2019, 07:43 PM   #3
neverdone
Looks perfect. I appreciate it. Btw, what calculator are you using to get the percentages? I want to use 245/35/19 and 265/35/19 for some other wheels..
      04-24-2019, 07:32 AM   #4
Flyguyin23
Flyguyin23's Avatar
46
Absolutely brother! https://www.fitmentindustries.com/tire-wheel-backspacing-offset-calculators
The calculations where on point for my fitment journey.
