2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums Regional Forums UK Whats included in 1st Service?
      09-20-2015, 05:59 AM   #1
Hasser
Hasser's Avatar
Isle of Man
447
Drives: 2014 F10 M5
I've got my 2014 active hybrid 5 booked in for its first service on Friday.
its all included with the service pack, so what gets done on the 1st service?
car is 2 years old as was built September 2013.
should I be asking for anything additional as part of the service pack.?
I am going to ask to see if they can increase the ambient light intensity, as its pretty low.
2014 M5
1990 E30 318i Touring
1999 E38 728i -sold
M235i - sold
Activehybrid 5 - sold
      09-20-2015, 03:37 PM   #2
Jocky Wilson
dArtist
Jocky Wilson's Avatar
Drives: BMW 520D Touring
The only way to increase the Ambient light is to turn it up yourself using the control to the right of the steering wheel.. It will however mean that the other instruments run at a very high brightness level.
This is a common complaint unfortunately.
BMW Touring 520D SE Auto - Imp Blue, Venetian Beige, Pro SatNav, Panoramic Sunroof, Heads Up Display, Active Cruise Control, Comfort Access, Extended Bluetooth
      09-20-2015, 04:05 PM   #3
Hasser
Hasser's Avatar
Isle of Man
447
Drives: 2014 F10 M5
It's up all the way and still not bright enough. I'm sure you can code it higher.
2014 M5
1999 E38 728i -sold
M235i - sold
      09-21-2015, 05:10 AM   #4
martin mustang
Ireland
257
Drives: 640d,X5 45e, 911c4s, 635csi
Few folks in this forum went for the option to change the lights behind them for LED or some stronger one’s, I am not sure codding can get you what you looking for.
      09-21-2015, 05:44 AM   #5
HighlandPete
Drives: BMW F11 535i Touring
Should be oil service and pollen filter change. Brake fluid was 2-years, but changed to 3-years, not sure where you fit for that part of the service regime.
Whether the AH5 has any more attention, no idea.
HighlandPete
      09-21-2015, 06:04 AM   #6
Hasser
Hasser's Avatar
Isle of Man
447
Drives: 2014 F10 M5
HighlandPete
Cheers
2014 M5
1999 E38 728i -sold
M235i - sold
      09-21-2015, 06:28 AM   #7
gspannu
Drives: F10 535, F82 M4
Coding can set the ambient lighting to be always at a higher value and the remaining instrument panel at a lower setting.
The main issue is that ambient lighting set at 100% is bright (maybe not super bright, but good enough) also causes the instrument cluster to be at 100% and this is a real pain. What most people wish is the ambient light to be brighter than the rest of the cluster.
With coding, you can set the ambient lighting to say 80% minimum, so that even when you decrease the brightness using the knob, the cluster dims down but the ambient lighting stays at 80% (or whatever value you code).
      09-21-2015, 07:51 AM   #8
Hasser
Hasser's Avatar
Isle of Man
447
Drives: 2014 F10 M5
Thought I read that somewhere.
Thanks.
2014 M5
1999 E38 728i -sold
M235i - sold
      09-22-2015, 02:25 AM   #9
martin mustang
Ireland
257
Good point, it is one way on making the light on the strong side, the inside trim can also have an effect on the brightness, my one is black hence probably not as good as to other lighter trims.
      10-05-2015, 02:10 PM   #10
Hasser
Hasser's Avatar
Isle of Man
447
Drives: 2014 F10 M5
Nothing extra being a hybrid.
Next service due sept 2016 / 6000 miles
2014 M5
1999 E38 728i -sold
M235i - sold
