2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes Upper Control Arm Part Help
      07-29-2018, 10:17 AM   #1
evanse
Drives: 2015 535i xDrive
Hi,
I was starting the install of ACS springs to my 2015 535i xDrive and I just couldn't get the upper control arm off of the knuckle pin by myself, so I went to put it back together. I pulled a torque from the forum @ 122 ft/lbs. Well that snapped the bolt. Probably because it is a one time use bolt, or that torque is wrong. Either way I need a part # and I can't seem to find it anywhere.
Has anyone replaced that bolt? Do you have a part number? And is that torque correct? Any help would be appreciated.
Also - I do have the m-package, but from what I've read, because it is an xDrive it is not any different than the non-m-package. Thanks
      07-29-2018, 11:15 AM   #2
.BMW.
.BMW.'s Avatar
Sweden
1863
Drives: BMW F11/F31
      07-29-2018, 12:06 PM   #3
.BMW.
.BMW.'s Avatar
Sweden
1863
Drives: BMW F11/F31
I cant find the correct torque now, but 122 ft lb is way too much.
The bolt is a M10x1.5 10.9 grade with Torx head, I expect the torque spec to be around 50 ft lb.
      07-29-2018, 12:10 PM   #4
evanse
Much appreciated!
      07-29-2018, 02:44 PM   #5
Stück
Stück's Avatar
Drives: F15 X5, E46 330i, R56 Mini.S
The torque spec for that bolt is 56nm (41 ft. lbs)
The nut should also be replaced any time it is taken loose.
      07-29-2018, 07:06 PM   #6
evanse
You guys rock. Thanks! New parts on the way.
