05-09-2022, 08:01 PM | #112 |
Rep 111
Will a 20x9 ET: 30 work on a 245/35/20 squared setup?
Current - 2025 G05 X5 xDrive40i, Black Sapphire Metallic
Sold - 2021 G01 X3 M40i, Black Sapphire Metallic Sold - 2016 F10 535i xDrive, JET BLACK |
06-13-2022, 05:37 PM | #116 |
Rep 22
06-13-2022, 06:30 PM | #117 |
Rep 1,287
06-15-2022, 01:22 AM | #122 | |
Rep 22
Yea I prefer higher sidewalls, thinking of switching my setup to 19s. I also love meaty tire setups. You ever go to any meets in socal? |
07-26-2022, 04:47 PM | #123 | |
Rep 2
Loving the setup! I'm currently purchasing the same wheels in black but the sale man recommended me 20x8.5 in the front. How are the 9.5 in the front, any clearance issues? Are 275 fit the front well? Are you on stock suspension? The fitment looks amazing ! |
07-30-2022, 09:34 AM | #124 | |
Rep 1,060
Yeah, Fast only recommends an 8.5" wheel which is what the car already has. The 9.5" on the front is not a bolt-on. I'm lowered on coilovers and have negative camber upper control arms to get these to fit with these 275/35-20 tires, which are 1" larger diameter than stock. This setup will rub with too much steering angle and enough compression. If you used stock diameter tires (275/30-20), or a narrower 255/35-20, the 9.5 might be an easier fit, but will still require significant lowering to keep it from poking. It takes a lot of messing around to get this stuff right, and then the proper wheel spacers to tune it in. My wheels are 45 offset with 15mm spacers front, 12mm rear. 15mm front are necessary to keep it from rubbing the suspension upright, an effective offset of 30mm. |
08-16-2022, 12:05 PM | #125 |
Rep 134
Just picked up a 2016 535i. Its got the 464M 20" factory upgrade. Thinking about something to lower it a tad. It has the M Sport suspension so it looks lower than stock height but i may want it a tad lower.
08-20-2022, 12:06 PM | #127 |
Rep 134
Just a few more pics…
Blue Angel1042.50 B-Buster24.00 |
09-25-2022, 10:27 PM | #130 |
Rep 2,352
Do you have any more pics of how the rear fit?
SCOTT26 "So as an admirer of the M5 and a potential customer of an M5 Touring. I would run naked around the streets of Garching if they were to offer one."
09-26-2022, 07:59 PM | #132 |
Rep 1,060
How to make brakes look small - 22" wheels!
I think your car will look MUCH better with 20's on it (and it will surely ride much better). Lots of M5 guys go to 21's and I think that's about the limit for this car, but personally I think 20's are the sweet spot. Lots of good tire choices too. |
