10-01-2022, 07:24 PM | #133 | |
Rep 2
Blue Angel1042.50 |
11-03-2022, 12:20 PM | #135 |
Rep 2,352
These are stock M5 wheels, style 343m, 20x9" 32mm and 20x10" 34mm
https://www.alloywheelsdirect.net/bm...43m_wheel_3038 For F10s they are a very good option as their width and offset allows for a fairly aggressive fitment, they are forged meaning they are lightweight and strong as well. Due to their width running 255/35r20 and 285/30r20 is a common fitment. The stock M5 sizes are 10mm wider each front and rear but for most people the 295s at the rear will rub
SCOTT26 "So as an admirer of the M5 and a potential customer of an M5 Touring. I would run naked around the streets of Garching if they were to offer one."
Blue Angel1042.50 |
11-05-2022, 02:56 AM | #136 | |
Rep 170
11-19-2022, 11:28 PM | #137 |
Who reads these?
234
Rep 107
OEM Style 87 from E53 4.6is
20 x 9.5" ET45 (20mm spacer so fitment is equal to a 9.5" ET25) 20 x 10.5" ET30
Instagram: daniel.35d
Blue Angel1042.50 BashBot_F100.00 |
11-21-2022, 11:35 AM | #139 | |
Who reads these?
234
Rep 107
I mistakenly chose a tire with rim protector, and since the tire was stretched a bit, it looked kinda weird + it stuck out a little more than what I think a tire without the protector would do. If that makes sense. But in theory it sits fairly flush with the ride height that I have. Would obviously go further in if I lowered it more.
Blue Angel1042.50 |
11-26-2022, 01:35 PM | #140 |
BMW enthusiast since 2004
370
Rep 188
For the next summer. 9,5x20 et37 and 11x20 et37. Three other needs a little work. Front wheels I gotta straighten and one rear wheel a friend is gonna weld small crack. |
12-12-2022, 03:40 PM | #141 | |
Rep 170
12-12-2022, 09:23 PM | #143 |
Rep 1,060
12-14-2022, 06:23 AM | #144 |
370
Rep 188
I had 10,5 et30 last summer, so should fit nicely. With 275/30R20 tire.
12-14-2022, 07:41 AM | #145 |
Rep 1,060
12-14-2022, 12:08 PM | #146 |
370
Rep 188
I was washing my car at work and was tempted to test fit them. I will be lowering it another 1-1,5cm for summer.
Front is with 17mm spacer, rear 5mm. Seems to fit nicely but gotta check it better once lowered. Last edited by zener; 12-18-2022 at 04:16 AM.. |
12-21-2022, 03:23 AM | #148 |
370
Rep 188
Yeah, I will test it more once it's time for summer tires. I remember wrong, it was 10,5 et30 last summer and with 11" it's more stretch so it has little more room.
12-28-2022, 03:29 PM | #150 |
Rep 2,352
F10 M5 style 343m. Don't get the M6 ones, they are quite different!
01-09-2023, 12:14 PM | #151 |
Rep 2,352
Are those 168m wheels from an E53? 20x9.5 45mm and 20x10.5 30mm? Do you have a spacer at the front? Also what sized tyres are you running?
01-13-2023, 08:15 PM | #153 |
Rep 252
19×9.5 +35f/ 20×10.5 +22R Artisa Elder, but look at that fittment with the stock winters tho. Idk What tire size yet,
01-21-2023, 09:09 PM | #154 |
Rep 1,060
Your fronts might need a spacer to clear the suspension upright. Your rears are going to poke by as much as 20mm unless you go stancenation with negative camber and/or super stretched tires.
