2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications Charge pressure too high
      09-17-2016, 03:47 AM   #1
Jrsimp78
Drives: 535i se auto saloon
Hi all
I'm having the occasional "drivetrain - drive moderately" usually under hard acceleration . Then goes into limp mode ( still drives nice but less power.
Can drive for hours and no issues but it's not nice thinking you may lose a load of power at any minute if you're overtaking
Codes are reading
Charging pressure control plausibility too high
Charging pressure control deactivation, pressure build up blocked
Air mass volume too high
And also
Power management, overvoltage
(I think this one may be irrelevant )
Is this the wastegate control valve or the diverter valve??
Has anyone tried cleaning the wastegate control valve . Seems an easy first attempt .
Any thoughts guys ?
Thanks in advance
2010 F10 535ise auto saloon, sophistico grey / oyster 331 19"
      09-17-2016, 08:49 AM   #2
Bmw doubles
Dream crusher
Bmw doubles's Avatar
Drives: Fast
2011 535  [0.00]
Stock or tuned?
IG: @bmwdoubles
      09-17-2016, 12:54 PM   #3
paul_sarky
Drives: 2012 BMW 550i M-Sport
Check your intake post MAF sensor, might have something loose or cracked, sucking in more air than it thinks it is causing it to over pressurize. Had that happen to me a few times, one of the intake rubber clamps got loose, easy fix if that's what it is.
      09-17-2016, 01:18 PM   #4
Jrsimp78
Hi , it's stock , zero mods.
I removed and cleans the boost control valve and checked the function of the wastegate actuator. (Seemed ok. The valve behaved a little differently after cleaning ( as in the way that air flows through the in and out. ) ok. I'm hoping it may have been sticking .
Test drive with multiple povokation ... no issues so far.
I'll double check for cracks / potential leak points .
Thanks for the help . I'll keep you posted on how it goes
      10-01-2016, 11:02 AM   #5
Jrsimp78
Issue has reoccurred . Now replaced the wastegate control valve. ( pressure converter) . The part number has been superceeded twice since the original . The new one has a much larger filter section on it so maybe it is recognised by BMW as being insufficiently robust.
Let's see how it's goes
      10-03-2016, 01:11 PM   #6
Jrsimp78
Fist long run since the boost control valve was change. No issues so far and the general performance seems better and more responsive. Not counting any chickens yet 🐔🐔🐔
      10-03-2016, 02:43 PM   #7
Secret_Asian
Drives: f10 lci luxury line
post up the part number you purchased
      10-12-2016, 12:30 PM   #8
Jrsimp78
Hi .
all isstill looking good
Old part no=11747584628
New part no =11747626351
