2010 2011 BMW 5 Series Forum F10 F10 Technical Topics DIY Guides & Discussions Help: Anyone installed Oil catch can for N20 engine (520i or 528i)
      12-18-2015, 03:55 AM   #1
moonriver
moonriver's Avatar
Drives: E46 -E90 -F30 - F10 520i
Hi all,
I got a oil catch can for my N20 engine, not sure about where it will be installed. I assume it will be at the pipe from engine to air intake line as picture below.
Does anyone have experience of it?
Thank you
      04-26-2017, 04:08 AM   #2
rustyminded
rustyminded's Avatar
248
Drives: BMW 328i
yes i did before and i mounted it on that solid arm left. works perfect with no problems
      01-14-2018, 09:48 AM   #3
milkdi
Drives: Not yet
I am looking to add this too. Which brand of OCC did you get? Can you show us a photo of how it looks after installation?
      02-01-2018, 07:20 PM   #4
moonriver
moonriver's Avatar
Hi,
There are several OCC you can get, I got Mishimoto brand.
Link order here:
https://www.ecstuning.com/b-mishimot...fiber/mmocccf/
Photo of after it is installed :
I have to cut oil suction line connect between crank case and intake tube. It requires reduction adapters (yellow cooper) to fit with OCC.
I have used OCC for 2 years and I only see very little oil in OCC, I believe N20 engine has a very good designed oil separator not like other previous engines. You should consider the need!
      04-26-2020, 03:28 AM   #5
ckaul
Drives: 2012 BMW 528i xDrive
What are the sizes of the reduction adapters and what did you use to mount the OCC?
Originally Posted by moonriver View Post
Hi,
Link order here:
      05-03-2020, 03:39 AM   #6
moonriver
moonriver's Avatar
Hi,
Link order here:
Hi,
I did not remember what size it is. After cut, I measured and got a local shop to make copper reducer. At that time there was not available completed OCC yet.
Now I see there are some completed OCC for this N20 engine, you should consider it
      05-14-2020, 05:13 PM   #7
ckaul
Hi,
Was it collecting a lot of oil by the way? And also the catch cans for the N20 motor are only for the 2-4 series. They dont fit the 5 series.. But I have everything ready I just have to figure out how to mount it. I am trying to find a bracket like the one you have on your car.
      05-15-2020, 09:38 AM   #8
moonriver
moonriver's Avatar
Hi,
Very little oil were found in OCC of my N20 520i after 20k miles. I checked it every 5k miles, it was almost completely dry, only thin dry oil layer found. I believe stock PCV working well for this engine.
      06-19-2020, 12:01 PM   #9
tringuyen7757
tringuyen7757's Avatar
Drives: 2014 BMW 528i
2014 BMW 528i  [7.20]
Hi,
Link order here:
Hi,
Do you know the name of the clip that you used to mount on that strut bar. I can't seem to find it anywhere.
Tri Nguyen
      09-06-2020, 07:04 AM   #10
moonriver
moonriver's Avatar
Hi, I also tried to find in ebay but can not see. The clips I bought from my local market here, it's easy to find!
      09-07-2020, 09:48 PM   #11
ckaul
Hey guys also have one installed on mine. Here is a pic. And if you like this mount as well, can send you the amazon link.
      10-07-2020, 09:30 AM   #12
moonriver
moonriver's Avatar
Wow it's nice!
Pls pls pm me
Thank you
      10-07-2020, 10:12 AM   #13
ckaul
Wow it's nice!
Pls pls pm me
Thank you
Done
      11-13-2020, 09:19 PM   #14
ngsir
Drives: BMW F10 520d
It will be my next project, any one who try it on a MY2014 520d? Thanks
      01-13-2022, 04:01 PM   #15
Pwilliams90
Drives: Bmw 528i
Have you noticed any increas of oil since the install? Wondering if it's even worth it for 528i f10
      01-13-2022, 04:04 PM   #16
Pwilliams90
Drives: Bmw 528i
Do you still have the link to the mounting bracket? Also, what can did you use? Did you have to modify it or the hoses at all?
      01-14-2022, 03:27 AM   #17
musclesmarinara75
musclesmarinara75's Avatar
2013 535 XDrive  [9.75]
OCC installed
I installed one on my 535..gets alot of that shit out so it's not going back through the intake and getting burned up in the ports.. I'll take more pics with the cover off, some trimming was needed and some fancy hose work.. but it's simple and well worth it IMO
      01-15-2022, 04:21 AM   #18
ptrkp
Drives: F10 or F11
Yes please.
      01-15-2022, 05:54 PM   #19
B-Buster
Netherlands
24
Drives: F10 535i, E63 650i
I would like to see this too, installed my Mishimoto CC in the same spot as yours, with the hoses routed like they advise for the F30 but that isn't it.
      01-16-2022, 05:52 PM   #20
musclesmarinara75
Ill take em as soon as I can, car is in shop waiting on new turbo
      12-19-2022, 07:01 AM   #21
hotpantss
Drives: bmw f10 n20
Thumbs up where to buy!@?
where to buy? let me know.
Thank you
