03-20-2017, 02:04 AM | #1 |
Rep 10
Soft door close noise
Hi guys I have a 2013 550i with the soft door close option and it just started making a loud noise after I close the door. The soft close function still works but it sounds like the motor or gears are getting stuck. Has anyone had this problem? I'd like to see if I can get any advice before I replace the actuator assembly. Thanks in advance.
10-07-2018, 09:26 PM | #3 |
Rep 1
Any update for this thread?
Can someone tell what Fuse I can pull off while I get it fixed? I hear a loud mechanical noise as if some thing is not latching on when soft closing the driver side door. |
11-30-2018, 04:36 AM | #4 |
Rep 951
reviving this thread. Wondering if a solution has been found other than replacing the whole mechanism. I have 3 doors that are noisy after closing. But one that acts like it should. Video links to issue as well as the one that seems to operate as designed:
And the correctly working one: |
11-30-2018, 10:33 AM | #5 |
Rep 7,569
Looks like Fuse #149...but You may want to check you fuse index to see if F149 controls other things that may be affected if you temporarily pull it.
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. |
11-30-2018, 04:00 PM | #6 | |
Rep 361
Janet Jackson Unbreakable World Tour
12-05-2018, 02:48 AM | #7 |
Rep 951
The concern is that the motor is working harder than it should and ultimates pushes the door a little further out. It also doesn't seem like a desirable sound from the setup. The rear door (second video) is always short a quick. The rest of the doors have this full motor cycle of pulling in..then pushing the door out..
05-18-2019, 03:00 PM | #10 | |
Rep 951
I am betting though it has to be some sort of alignment issue of the latch like another poster here. I never ended up trying to move the bracket on the pillar that the latch closes on. I think that might be the actual solution since I know the car was repainted before I got it so it just may have not been aligned better at the time. |
