2010 2011 BMW 5 Series Forum F10 550i exhaust tip removal |
02-13-2012, 04:54 PM | #1 |
Rep 144
Can anyone describe the steps required to remove the exhaust tips on the 550...just the tips...I don't want to chop and re-weld new pipes, just want to tack weld new tips in place. If anyone can help, I would greatly appreciate it.
I have searched and there isnt a clear set of instruction or description on removal of stop trapizoidal tips? What should be noted and what should be looked out for and what best recommended set of steps are to be taken..etc. Thanks in advance. |
02-13-2012, 05:29 PM | #2 |
Rep 102
Check out this thread for one approach. I purchased the same Borla tips (chrome to be painted black chrome) and plan to install them in the same manner.
http://f10.5post.com/forums/showthread.php?t=630331 |
02-13-2012, 09:08 PM | #3 |
Rep 144
Thanks for the link...I take it there isn't anyway to modify just the exhaust tip...because the link provided has the pipes cut off from the the edge of the muffler onwards...the flap valve included...is the flap valve not important!? Will it bring up a error code?
02-13-2012, 10:30 PM | #4 |
Rep 102
If you read the thread, someone posted a link to another thread that explains the function of the butterfly valve on the mufflers. Several people have posted about blocking the valve open, with the only result being a bit more exhaust note.
08-19-2012, 01:43 PM | #6 |
Rep 1,583
If your not going to use the back pressure hoses with valve control definitely plug them good. You don't want to leave them open.
2013 M6 Coupe SG, VSE 003's 21, Akropovic Evo Carbon, KW V3, AMS DP's, Vorsteiner Full Aero, Gruppe M Intake, Bel Stir Plus & V1 with HP Laser Interceptors, P3Cars Gauges, JL 2X12W6Subs, 35%tints.
My Thread: http://www.6post.com/forums/showthread.php?t=794659 |
