2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes Which sway bar for 2015 535i drive?
      07-05-2018, 02:36 PM   #1
andykap
Drives: '15 BMW 535 MSport
I have a 2015 535i xdrive and I looking to buy a set of sway bars. In my search I keep getting does not fit my model.
I have look at H&R - model numbers 70470 (F) and 71470 (R) and most sites say it does not fit my car.
Anyone knows if those will fit or can suggest ones that do?
Thanks in advance.
      07-09-2018, 04:33 AM   #2
andykap
No one knows if the H&R sway bars works with the 2015 535 xdrive or what works?
      07-09-2018, 10:10 AM   #3
ChiNorm
Drives: '13 535xi
Eibach for F10 RWD will fit. They were much too stiff for Chicago's lousy roads. Do some research on M5 front and 650i rear, which will also fit and are softer, but still too stiff for me.
I ended up with the KW V3 coilovers, which I like much better. The car is far superior to stock in every way.
Good luck.
      07-09-2018, 10:54 AM   #4
andykap
Good luck.
Thanks.
Did you put the stock sway bars back on with the KW V3?
That is the route I thought about going.
      07-09-2018, 11:46 AM   #5
John H.
John H.'s Avatar
Drives: 2014 535i XDrive
On my 2014 X, I went with the OEM M5/6 set-up. Also, I installed H&R springs. Very happy with set-up.
      07-09-2018, 12:09 PM   #6
neverdone
Drives: X5, 335, Ford Lightning, 63 me
Can I see pics of this?
      07-09-2018, 01:19 PM   #7
ChiNorm
Drives: '13 535xi
Originally Posted by andykap View Post
Thanks.
Yes, I have the stock bars again. The car corners totally flat. Its quite impressive. My indy mechanic said he wished he put this on his wife's car instead Bilsteins.
If you go this route, get the K3 installed by someone who is really good with alignments as the K3 will drop the car a minimum of about 3/4" which makes the alignment a tricky business. The KW website will list authorized dealers in your area. If I had to do the job again, I would give the job to an authorized KW dealer.
Good luck.
      07-09-2018, 03:30 PM   #8
John H.
John H.'s Avatar
What exactly did you want a pics of?
      07-09-2018, 05:21 PM   #9
neverdone
Sorry, of how the car sits with the springs...
      07-09-2018, 07:32 PM   #10
andykap
Good luck.
Thanks very much. I will do that.
      07-10-2018, 10:50 AM   #11
Surly73
Drives: '11 535xi 8AT KWv3 MPE MHD xHP
They fit on mine, but I agree that H&R, Eibach, etc... all indicate that they aren't for the X-Drive. There's always the possibility that there's another reason other than fit - overstressing some suspension component perhaps? You just never know.
      07-10-2018, 04:27 PM   #12
ChiNorm
Drives: '13 535xi
That's a big part of why I went for the K3. It is rated for the AWD platform and is a different product than what they sell for RWD.
Good luck.
      07-12-2018, 02:51 PM   #13
John H.
John H.'s Avatar
About 10 minutes ago, took below pic...
[/URL]
      07-12-2018, 04:27 PM   #14
neverdone
[/URL]
How does it ride compared to stock? I'm sure you've been asked many times. But going off looks alone, I'm sold.
      07-12-2018, 05:31 PM   #15
John H.
John H.'s Avatar
It is little more stiff than the stock springs; however, comfortable. These H&R springs are specific to x-Drive. Keep in mind that my struts are stock. I frequently drive to Los Angeles, and San Diego, no complaints on ride quality.
As for the M5/6 sway bar combo, it helped in the cornering dept. I considered thicker bars but didn't want to get too aggressive. The OEM upgrade is a good compliment to the springs.
      07-12-2018, 06:35 PM   #16
neverdone
Thanks for the info, great help.
      07-13-2018, 05:15 AM   #17
andykap
You have both the M5/650 sway bars and the V3. Did you install them at the same time? If not, which was installed first. How was the ride with either when installed?
I’m sold on the V3, but still on the fence with the sway bars.
      07-13-2018, 04:23 PM   #18
John H.
John H.'s Avatar
Hi Andy:
No V3, only H&R springs.
My suspension related mods...
H&R Springs, 50471
OEM M5 Front Sway, 31352284460
OEM 6 Rear Sway, 33556791932
I purchased the front sway from a local Member. It was the first thing installed. IF I remember correctly, the springs next, and finished with the rear sway (ordered from ECS).
      07-15-2018, 05:09 AM   #19
andykap
Hi Andy:
H&R Springs, 50471
Hi John,
Thanks for the part numbers. Will be looking into them soon.
      07-15-2018, 12:39 PM   #20
valbmw
valbmw's Avatar
94
Drives: 2016 BMW F10 M5 CP 600 hp
The H&R set 33894-1 fits perfectly whatever xDrive or not. I've got it installed a year ago, and honestly this is the best simple upgrade for its money. Drive and cornering is now as it should be.
I didn't go for M5/650 set because it is thinner. And also the M5 sway bar has different angles so install is possible but not totally good. Joint bolts will be tilt out.
Please see below some pics of the process.
