2010 2011 BMW 5 Series Forum F10 G30 M sport steering retrofitted to F10 535i |
02-16-2021, 11:05 PM | #24 | |
Rep 2,591
Just to shed light on how much fuckery BMW does with steering wheels: The F10 pre-LCI paddle shifters put out different resistance values compared to the F10 LCI paddle shifters, rendering the paddles incompatible between the two cars. And that's for a facelift of the same generation. You really expect cross-generational buttons to share the same signal values? Pffft quit clowning
2015 BMW 535xi
02-17-2021, 04:14 AM | #25 |
Rep 277
02-17-2021, 10:38 AM | #26 |
Freude am Fahren
479
Rep 362
Drives: G26 i4 M50, F11 M550d, E70 X5
Garage List 2011 BMW E70 X5 xDr ... [0.00]
2015 BMW F11 M550d ... [0.00] 2024 BMW G26 i4 M50 ... [0.00] 2009 730dA [10.00] |
Isnt the wiring, connectors and pinout the same? I will look at the same project for my i3S, but waiting for some parts.
OEM+ customization is the way to go!
02-25-2021, 12:36 PM | #27 |
Rep 277
Yes wiring and connector are the same, the differences are the vibro/heating module and touch module (traffic jam assist) and the biggest problem is that the buttons send out a different signal why nothing works.
02-25-2021, 06:02 PM | #28 |
Freude am Fahren
479
Rep 362
Ok, so if you use the F-series steering column ECU (the little black box in the steering wheel), it should work in my opinion (?).
02-25-2021, 10:36 PM | #29 |
Rep 2,591
No, the button themselves are the ones sending out the signals, the box just interprets the signals. It's not a straight on off signal.
2015 BMW 535xi
02-26-2021, 06:45 AM | #30 | |
Rep 277
Its like Unspec says the electric boards inside the buttons need to change so the send the same signal as an f series. Achtually the only way to get this to work is internal the steering wheel has to be like an f and just the exterior is g. |
03-03-2021, 05:15 AM | #31 |
Mr. OEM
542
Rep 796
Actually it is on the right side.
Which is the wrong side. As left side is the right side.
'1998 BMW M3 3.2 Cabrio • Alpinweiß III auf Schwarz • Deutschland-ausführung • 1 von 12 • SMG • SRA • PDC • AUC • GSM • HK • UURS • IHKA • FGR • MFL • |
03-03-2021, 05:20 AM | #32 | |
Mr. OEM
542
Rep 796
Had the paddles (which match the e36 M3 stock shifter perfectly) only to find out they were not simple make/break contact paddles, but working with different resistance. Really!? Well long story short, a friend of mine who can work with microelectronics, converted the little pcb's into on/off contacts and I had working paddles.
