2010 2011 BMW 5 Series Forum F10 FULL dashboard ambient lighting |
01-15-2022, 11:11 AM | #1 |
Rep 808
I have a 2011 f10 with the ambient lighting package that is just the amber color on the door trims and pockets. I am wanting to add it to the dashboard, including under the idrive screen and headlight switch- maybe change the rest of the lighting to multicolor, as shown in the pic. Anyone do anything like this? Suggestions?
02-12-2022, 12:20 AM | #2 |
Rep 117
Drives: 2013 F30, 06 325i, 07 328i
I also have a 2011 F10 and I am interested in doing this mod. The lighting in that picture you posted is badass!! I am sure that many F10 owners would be interested in doing this. I am researching it currently. Hopefully some other members will jump in and together we can sort this out and write up a DIY on this mod..Where you find that picture ?
02-21-2022, 01:11 AM | #4 | |
Rep 262
But just make sure you buy the more expensive unit with the 9 color options if you want more than red and blue. I believe the 2color systems have a button on the LED strip to change the colors, the 9 color unit has 2 options depending on whether it's NBT or not, for NBT you control thru iDrive (I believe) whereas I have to manage color and brightness thru my radio keys. But if your interested I can try and put together a write-up/how-to. Just need temps above 40/50's, my desk job has made me a sissy for cold temps.
2011 550i (N63)
Upgraded 51mm turbos, Heatsync Stage 3 Flash, JB4 stacked, BMS WMI, Arm Charge Pipes, Heatsync Catless DPs, X-Pipe, Res Muffler Delete, xHP Stage 3 Trans Flash, Turbosmart Diverter Valves, 3.5 TMAPs, Oil Cooler, Heatsync Front Mounted Max Cool Intakes, Walbro LPFP and e40 mix rollin on Stance SF07 9x20 w/Toyo Extensa and 10.5x20 w/Toyo R888R. |
UncleRashid0.00 |
04-07-2022, 12:36 AM | #5 | ||
Rep 808
04-07-2022, 04:04 PM | #6 |
Rep 5,402
Here's a video installing colored ambient lighting for pre-LCI F10's. It's only $50. I would probably splurge, but I have an LCI F10. Grant is a member here.
