2010 2011 BMW 5 Series Forum F10 catless downpipe for 535 opinions |
04-24-2015, 03:15 PM | #1 |
Rep 1,108
been debating whether i wanted to do this or not. are the gains noticable, does it sound better? i also have a jb4 tune on it as well. any input is appreciated.
04-24-2015, 04:10 PM | #2 |
Rep 844
There are a few guys on N54tech running full setups, unfortunately the consensus (personally discovered as well) is that the single turbo on the N55 is just maxed out from the factory. You will get it to spool quicker with a downpipe and might pick up a few hp up top, but the only way guys are really making power with those is big exhaust and downpipe, intake, JB4 or similar, E85 mix and some of the guys have gone to larger intercooler setups and charge pipes, and even then the gains are VERY minimal up top where you need the power, most of it is just down low where you dont.
If you wanted to invest your money wisely though, get one of the upgraded turbos that have the larger impeller wheels in them, a good custom tune and a downpipe. You will make some SERIOUS power on that car and actually get your moneys worth instead of investing 4K in mods to gain 30-40 horsepower if youre lucky (almost ALL of the power gained on the N55 is below 4500 rpm, which is the point the factory turbo starts to run out of air and fall on its face, this is also completely useless power as youre out of 1st gear in under 2 seconds and never go below 5500 rpm again) |
04-24-2015, 04:32 PM | #3 | |
Rep 1,108
04-24-2015, 07:06 PM | #4 | |
Rep 14,522
04-24-2015, 09:01 PM | #5 |
Rep 176
From the research and dyno I have seen, actually a downpipe over just Jb4 can result around 20 peak whp more which is not bad for the cost of it.
Stock car dyno around 265whp Jb4 Stage 1 around 285-290whp JB4 Stage 2 with cat less downpipe around 305-310whp. Also based on dyno I have seen and gear ratio on a stage 2 optimal ship point are Gear / Gear Ratio / RPM Start after shift / RPM shift 1 4,71 2500 6750 2 3,14 4500 6750 3 2,11 4535 6250 4 1,67 4946 6250 5 1,29 4827 6250 6 1 4844 6000 7 0,84 5040 6250 8 0,67 4985 6000 The result of JB4 and downpipe if you shift correctly based on the new lower RPM reality is you have around 40-45 more whp at any time during the acceleration. Much less than N54 but still very good for a around 1000$ of upgrade. After that if you want a bit more next logical update is Pure or VTT stage 1 upgrade which is another 1000$ + 5-10hours of labor and will probably give you another 45whp and gain back your 6000+ rpms. I will install JB4 and ER downpipe next month so I will update you about it and if my expectation were met. |
04-24-2015, 10:23 PM | #7 | |
Rep 844
04-25-2015, 07:24 AM | #8 | |
Rep 176
Edit, just realized was in this forum
http://f10.5post.com/forums/showthread.php?t=595275 Quote:
04-25-2015, 08:16 PM | #10 | |
Rep 844
04-25-2015, 08:30 PM | #11 |
Rep 844
99% of BMW owners go off "feeling fast" to gauge power gains, so unless you have a dyno graph or some 1/4 mile slips to show gains, im just going by those who have actually supplied them and trying to save the guy some money.
04-25-2015, 09:04 PM | #12 |
Rep 18,713
Came across this thread. Here I share my F15 sDrive35i with JB4 Stage 2, Air Intake, ER prototype catless downpipe, ER Chargepipe, and RG Sport prototype muffler dyno result before and after the catless downpipe.
My mods portfolio http://f15.bimmerpost.com/forums/sho...d.php?t=967383
04-26-2015, 01:11 PM | #13 | ||
Rep 176
JB Stage 1 Downpipe Exhaust Drop in K&N... 91oct pump gas So nothing extreme there... Not even JB4 (JB stage 1 only with more boost), no meth... Quote:
04-26-2015, 01:26 PM | #14 |
Rep 844
04-26-2015, 06:16 PM | #15 |
Rep 176
It depends by to what extend your asking my understanding.
JB is a old version of the processor (called JB3) and is connected to less sensors. Generally JB stage 1 is less smooth and you have less control compared to JB4. In fact only have one map and you cannot upgrade it (except boost adjustments). JB4 is the latest processor and connect to more sensor making a smoother power curve and generally able to gain a bit more HP. Also JB4 have specific MAP depending on modification (Map 1 for JB4 only, Map 2 for exhaust modification and 94 oct... So JB4 will give more power for car with Exhaust, intake mods etc. So technically if the guy I posted his dyno would have been using JB4 on map 2 or map 5 he could have gained more whp over JB stage 1. Make sense? |
04-26-2015, 06:50 PM | #16 | |
Rep 844
In this case, the stage 1 runs at 2.5-3 lbs as factory setup per Burger. The one in the link is running 4.5 lbs, which is usually what the JB4s run in factory form and really pushing it for 91 octane. Therefore, "not even JB4" may not even make much of a difference in power output, albeit there will be a difference in how the car responds with the abilities of other sensor interference. What im trying to get at here is bench racing based on dyno numbers you found somewhere with the expectations that "well if he added XX parts, he would be even faster!" doesnt work. What does work is doing the parts yourself, strapping your car on a dyno (or going to the track for before and after results) and posting your results if you want a solid argument with me. 91 octane varies in content state by state with ethanol content, in addition elevation and temperatures make a huge difference. One guy picking up 30 with Combo A may yield a 10 horsepower loss on another car. Whether or not he buys the downpipes wont affect my life in the slightest, im just trying to prepare him for the simple fact that he may (and likely) wont see significant gains for the investment hes going to put into it. If he wants a super loud race car and is looking forward to spending $3,000+ (more if hes not doing the labor) with the hopes of 30-40 horsepower, then more power to him. Ive always learned to never expect what the top guy gets, and sometimes more than the bottom guy, and in the end if thats still satisfactory, then make the investment. Now what you also have to understand is the turbo on the 535s is severely limited by how much air it can physically push. Better fuels allow for more timing and/or boost where available, but overspinning a turbo out of its efficiency range isnt exactly the best idea if you want everything to last a long time, in addition without E85 or methanol, you are going to skyrocket intake air temperatures to where you not only lose power, but you make it dangerous. Things like downpipes and intakes do help for efficiency to get that last horsepower out of the turbo, but it still has limits. Anyway, these parts typically never hurt, just make sure the payoff is worth the investment. |
04-28-2015, 01:34 PM | #17 |
Rep 30
One of the biggest drawbacks to a catless downpipe on an N55 is that the motor won't idle for very long before it stalls. You have to hit the gas slightly to bring the idle up or it stalls. This is a common issue if you do a little searching.
I have a DP on my 535, and I like the way it feels (I have dynoed it - was around 15hp max gain, I believe below 4500rpms but i'll have to dig out the graph. Video of one of the dyno runs is on youtube) but the stalling issue is a minor aggravation. I can't imagine how the guys with an automatic or whatever the other option is, wannabe F1 or whatever its called (smg? dct?), can run the downpipe and not have the stalling thing drive them crazy. |
04-28-2015, 10:12 PM | #18 |
Rep 1,126
My 535i has never stalled. I put on down pipe and jb4 at 1200 miles, car has 21000 miles, not a single issue. I have flex fuel wires installed as well, run 50/50 gas & ethanol on map 7 for about 8k miles with no issue at all. Only issue I have rear tires burning up quicker.
ultraboosted15.00 |
04-29-2015, 01:17 PM | #19 |
Joint Chiefs of Staff
24174
Rep 190,750
N55 is maxed out from the factory ? What ?? !!!
Here is a dyno with the same engine. You can see stock power, versus map1 on a stock car versus map 2 with a car running catless DP versus map 7 on a car running catless DP and E85
04-29-2015, 06:18 PM | #21 | |
Rep 176
For some reasons 335I or 435I N55 dyno always show much higher number vs the F10 where we rarely see anything above 310whp. Also from what I see from the dyno you posted is that once you have a tune nothing will be added past 6k rpm but you are still gaining peak HP but at much lower RPM vs stock curve (between 4.7K to 5.5K RPMs). Last edited by Jayphil; 04-29-2015 at 06:28 PM.. |
04-29-2015, 06:46 PM | #22 | |
24174
Rep 190,750
