2010 2011 BMW 5 Series Forum F10 Do you have the adaptive LED's? - Get in here please! :) |
10-18-2013, 12:52 AM | #24 | |
Rep 63
If I lived in US and bought the LED lights I would be furious getting that trimmed down version without full disclosure from the dealer. |
10-18-2013, 08:17 PM | #25 | ||
Veteran U.S. Army
60
Rep 771
10-20-2013, 01:32 AM | #26 |
Rep 63
Update:
My adaptive LED headlights do work Thank you, it was simply because I misunderstood the option within the i-drive menu. I'm pretty impressed with the technology, it's interesting to see how the headlights try to light up as much of the road as possible without blinding the other drivers. I would like to increase the sensitivity so they're activated earlier. I haven't figured out the parameters yet but it seems like they tend to be activated above a certain speed. It would be interesting to know how variables that can be changed via coding. |
10-22-2013, 02:03 PM | #31 |
Rep 342
I picked up my car the other night, and while going over things, my SA confirmed that the auto high beams turn BOTH beams on and off, not just one side. This is for a U.S. spec'd car.
10-22-2013, 05:26 PM | #32 |
Rep 670
I'm quite pissed ... I opted for the LEDs on my '14 550xi and now come to find out thaat they don't work as advertised, and I pickup my car next Monday! I hope the coders can figure this one out!
10-22-2013, 07:32 PM | #33 |
Rep 7
The LED headlights shift slightly left to right as you turn the steering wheel. The best way to see this is to have the headlights shine on the garage door or wall. When you turn the wheel, you will see the shift.
10-22-2013, 10:37 PM | #34 | |
Rep 63
The consensus is that the lights are delivered in US spec'ed cars with missing features. |
10-23-2013, 12:00 AM | #35 |
Rep 1,250
Drives: 20' X3M CP
used it for first time tonight. pretty bad ass i must say.
2020 X3M CP - IND Reflector set | Ceramic Tint
Retired:2015 M5 CP MSR Intake|Carbon Fiber Fender Vents|Meisterschaft GTC catback with LXR mid pipes and ER Catless DPs | BPMSPORT Stage II Tune | RKP Rear Diffuser and Challenge Center piece |RKP Front Lip| Painted Reflectors | H&R Springs | Strasse SM5R Carbon Fiber Wheels | Nitto R888 | |
10-23-2013, 12:45 AM | #36 | |
Rep 7
2014 535i - Modern Lines, Driver Assistance Plus with ACC Stop & Go, LED Lighting, Premium. -Production completed July 3rd, Arrived at Port Hueneme August 1st - Received 8/10/2013 - BMWCCA Member!! |
10-23-2013, 04:11 AM | #37 | ||
Rep 63
I meant missing 'hardware' not 'feature' - the missing feature is because of the missing hardware. It can't be coded. But that's not the topic of this thread. Quote:
And I'm not complaining at all. I think you misunderstood something |
10-29-2013, 08:41 PM | #38 |
Rep 653
OP: could we arrange to read the coding data off your modules?
I'd like to compare to the values to a US-spec'ed car. This is the only way to find out whether this is a hardware or regional specs issue or both. |
10-29-2013, 08:59 PM | #39 | |
Rep 553
2011-12 (CIC) FRM => 3050 => FLA_VERBAUT => aktiv FRM => 3050 => FLA_AUTO_AKTIV => automatisch KAFAS2 => 3050 => FLA_ON_OFF => aktiv HU_CIC => 3000 => HIGH_BEAM_ASSISTANT => aktiv 2012-13 (NBT) and 2014 LCI FRM => 3050 => FLA_VERBAUT => aktiv FRM => 3050 => FLA_AUTO_AKTIV => automatisch KAFAS2 => 3050 => FLA_ON_OFF => aktiv HU_NBT => 3000 => HIGH_BEAM_ASSISTANT => aktiv
Regards,
MWPos |
10-29-2013, 09:15 PM | #40 |
Rep 585
11-06-2013, 12:24 PM | #43 |
Rep 169
Drives: LCI F11 MSport Xdrive (I.Blue)
11-06-2013, 05:57 PM | #44 |
Rep 1,133
I checked real OEM and the European and US cars have the same LED part #'s for all the components in the headlight housing. If they are correct it's just coding to get it working. Hopefully some European owners will send their entire SVT tree for comparison with US models. I know there's more to the coding than just removing 5AP and 8S4 from the VO. There's 2 TSM modules that have all the LED headlight data so I'm betting those modules will have to be coded as well.
It's good to be bad
