03-03-2018, 08:53 PM | #1 |
Rep 182
AC leak help?!
I recharged my ac and with a week it's not blowing cold air anymore. The AC compressor does engage I believed (I can see the pulley active on it when the AC button is on)? I'm not a mechanic but I do like to work on my car as much as possible if I have the proper tool to do so. How do I find if I have a leak in the ac lines or go about diagnosing this problem myself?
Thank you. |
03-17-2018, 09:38 AM | #3 |
Rep 1,214
Why did you recharge your AC system?
What is the current refrigerant fill, or at least what was it at the time you recharged it? Charging the system to specification and adding dye infused PAG oil is the normal way to find leaks. The green dye will leak out along with the refrigerant and a UV light will make it glow brightly showing the leak source. The condenser is the most common leak source I've seen on F10's. |
jooobi377.50 |
03-19-2018, 07:51 PM | #4 |
Rep 623
Drives: F10 530d M Sport, E87 118d M
There are numerous threads dating back 3 years or more on the rather common problem of F10 aircon condenser issues. Initially these problems were blamed on mechanical damage but now appear to be universally treated as a design fault.
jooobi377.50 |
03-20-2018, 02:03 PM | #5 | |
Rep 182
Thanks everyone for the reply! |
03-22-2018, 06:08 PM | #7 | |
Rep 4,632
My condenser went on my 14 535i with 19K miles... Replaced with a Different, newer part number in mid 2017.. Hopefully thats a fix.
Current: E63S AMG 4matic RENNtech || M5 Evolve..Eventuri || F10 LCI 535i MHD
