2010 2011 BMW 5 Series Forum F10 Pre LCI (non M-Sport) paddle shift retro fit |
02-20-2014, 08:20 AM | #1 |
G-MAN
44
Rep 241
I changed my boring non M-Sport steering wheel to a 2014 F30 M-Sport. If you don't care about the paddles then its a direct swap, no coding and splicing of wires. It has that sportier look and thicker feel. All buttons works. PLUG N PLAY!!!
Now, my 2012 F10 did not come with the paddle shift so I need to code it. I want to reach out to any member who successfully done the paddle shift conversion on a pre-LCI, non-Msport, non-paddle shift car. Last edited by sgt_gman2005; 07-24-2014 at 10:21 PM.. |
02-20-2014, 08:31 AM | #2 |
Rep 1,363
Looks much better. I've been wanting to do this myself, but didnt know F30 steering wheels fit F10s.
Would you mind sharing where you got the wheel and airbag? |
02-20-2014, 10:10 AM | #4 |
Rep 619
How about here....
http://www.ebay.co.uk/itm/NEW-BMW-M-...e#ht_22wt_1275 or here with airbag s/h http://www.ebay.co.uk/itm/BMW-3-SERI...7#ht_63wt_1275
2017 F10 535d MSport Auto - Mineral Grey - Oyster leather - 19" 351M's - Pro Media - Enhanced bluetooth - MSport rear spoiler - Sun protection glass - Harman Kardon Hifi - Multi Function Display - Ambient Lighting - Folding mirrors - Sunroof - LED adaptive headlights
02-20-2014, 10:34 AM | #5 |
Rep 8,279
Also to the OP. I sold an Msport steering wheel to a member that had the same wheel as yours with no paddles and he had a member code the paddles to work for him.
I think the member name was @Mwpos Last edited by LACSTER; 02-20-2014 at 12:09 PM.. |
02-20-2014, 11:28 AM | #6 | |
Rep 1,363
02-20-2014, 11:38 AM | #7 |
Rep 553
I did do the coding on Evolve's retrofit with advice and backup from Shawn. Here's the general procedue to enable paddle-shift functionaility and S1, S2...S7 gear indications on the cluster:
- Add Paddle Shifter Functionality for retrofit Sport Paddles FA (VO) Replace 205 with 2TB. Code new FA in ECUs ICM, EGS, GWS, and SZL This is the high-level procedure. There are some underlying details which are equally clear and well-documented.
Regards,
MWPos |
02-20-2014, 12:09 PM | #8 | |
Rep 8,279
02-20-2014, 06:25 PM | #10 |
Rep 1,363
02-21-2014, 09:26 AM | #11 | |
Rep 937
By the way, another item to share is that shipping airbags is extremely difficult in the US. They are considered hazardous materials. |
02-21-2014, 09:37 AM | #12 |
Rep 8,279
OP, are you sure that you installed an F30 steering wheel?
I tried to do the swap yesterday with my daughter's F30 sport wheel and the little mount that the steering wheel goes on is bigger on the F30 than it is on the F10. I couldn't install the F10 steering wheel onto the F30 because of that. I'm assuimg your F30 steering wheel was loose fitting when you installed it on your F10 correct? |
02-21-2014, 12:03 PM | #13 | |||
G-MAN
44
Rep 241
Thanks Quote:
Cheapest ive seen is ebay at $500 with shipping and HAZMAT fees. Quote:
The spline and center bolt fits perfect. I hate to hear that there are manufacturing versions for these steering wheel. BLUF, my set-up is a F30 steering wheel from Germany mated with a US spec airbag (dual inflator) PN: 32307845798. Thanks Last edited by sgt_gman2005; 02-22-2014 at 08:36 AM.. |
02-22-2014, 07:18 PM | #14 |
Rep 553
Evolve did his own retrofit...I never saw any work that he did before he brought the car to me for coding so I apologize, but I cannot offer an intelligent answer to your question. His car does not have the lane departure warning system.
And when you have your schedule for a trip to San Diego, send me a PM and I will for sure take care of any coding you need.
Regards,
MWPos |
07-25-2014, 05:53 AM | #15 |
Rep 947
[QUOTE=sgt_gman2005;15475709]I changed my boring non M-Sport steering wheel to a 2014 F30 M-Sport. If you don't care about the paddles then its a direct swap, no coding and splicing of wires. It has that sportier look and thicker feel. All buttons works. PLUG N PLAY!!!
Now, my 2012 F10 did not come with the paddle shift so I need to code it. I want to reach out to any member who successfully done the paddle shift conversion on a pre-LCI, non-Msport, non-paddle shift car. Soooo ... if I wanted to swap in carbon fibre instead of the fake alloy strip in the LCI steering wheel then do I need to remove the centre airbag pod to do that or is it simply removing a screw at the back of the steering wheel and that strip pops out?
Current Mistress: 2014 F10 535D M Sport - Alpine White
Retired but not forgotten: 2011 F10 535i - Titan Silver; E53 X5 4.4L Sport - Space Grey; E46 M3 Individual Convertible - Phoenix Yellow; E39 528 - Glacier Green; E36 328 Convertible - Montreal Blue |
07-25-2014, 08:49 AM | #16 | |
G-MAN
44
Rep 241
i think its better to remove the whole steering wheel in order to replace trim. its way easier. you can do these steps in 5 mins! steps: 1. disconnect battery (-) negative terminal 2. follow this video for airbag removal. same concept on the LCI Msport steering wheel 3. remove center bolt 4. remove steering wheel Last edited by sgt_gman2005; 07-25-2014 at 08:55 AM.. |
07-25-2014, 12:32 PM | #17 |
Rep 29,202
Are they the same diameter, or are the one from the f30 a little smaller?
07-25-2014, 05:54 PM | #18 | |
G-MAN
44
Rep 241
When I bought mine from ebay (seller is from Germany), the description stated F30 http://www.ebay.com/itm/NEW-BMW-M-le...3D261391914586. I did stated that my car is a 2012 F10 to the ebay seller. He probably followed that. To be safe, just stick to the F10 steering wheel. Same price. Last edited by sgt_gman2005; 07-25-2014 at 06:03 PM.. |
07-26-2014, 05:00 PM | #19 | |
Rep 29,202
07-27-2014, 07:24 PM | #20 |
G-MAN
44
Rep 241
02-28-2015, 02:13 AM | #21 |
Rep 166
What people miss out on in the swap guides is the yellow airbag cable. The danger is that you keep thinking it needs a proper pull. By doing that, you risk damaging the airbag cable.
Take a very close look at the connector while in the socket. There are two, tiny clips you will have to release by lifting the plastic cover plate carefully away from the socket. The rest is self-explanatory
Current: 2012 E92 335
Retired: 2012 F10 535, 2008 E92 335, 2003 E46 330 |
slimjoey0.00 |
03-28-2015, 05:06 AM | #22 |
Rep 1
I'm trying to find a steering wheel for my 2011 F10...I need one that's heated, has ACC buttons and lane deviance vibration...
I've found one that's for the X5 F15, anyone know if that'll work? Where do other people look? Not much for sale with the above specs on Ebay... |
