2010 2011 BMW 5 Series Forum F10 Random Misfire N55 - heavy accel |
06-15-2020, 08:39 PM | #23 | ||
Rep 1,261
06-15-2020, 09:09 PM | #24 |
Rep 1,299
06-15-2020, 09:12 PM | #25 |
Rep 1,261
Looks like the recall was until 7/11. Mine was a 2012 manufactured 11/2011
06-20-2020, 10:29 AM | #26 |
Rep 8
Good Day All, I am having some random misfire on multiple cylinders(5,6),Replaced all 6 plugs and coils,LPFP and LPFP sensor,moved out coil 5 with 4 and 6 with 3 and the problem not following the move,Replace the plugs(Again)...it remains intermittent start is very smooth only when you put it under load stutters and then drive train light...Not sure what to do next ..HPFP or Injectors...
06-20-2020, 12:47 PM | #27 | |
Rep 109
06-20-2020, 09:17 PM | #28 | |
Rep 1,261
06-21-2020, 07:21 AM | #29 | |
Rep 8
On start smooth(in P) in Load(R or D) Initial slight stutter,if i drive slow below 2000 it seems fine but you can feel and hear the stutter during gear shift. Thanks |
06-21-2020, 07:24 AM | #30 | |
Rep 8
Thanks |
06-21-2020, 09:18 AM | #31 | ||
Rep 1,261
06-21-2020, 12:00 PM | #32 | ||
Rep 1,261
06-21-2020, 01:28 PM | #33 |
Rep 79
you mentioned you have misfire only in cylinder 5,6. Even with the new parts and after a swap. Wouldn't a bad hpfp affects all cylinders?
You can monitor hpfp pressure under wot, so you know if its the issue. Do you have any codes in ISTA-D? Last edited by mashpotato; 06-21-2020 at 01:35 PM.. |
06-22-2020, 04:00 AM | #34 |
Rep 8
I did mention that i am getting a random misfire as it moves around,I did not ISTA-D code,well my report from the company that did the test has no other codes,my OBD2 / EOBD(Konnwei KW818) reader only confirms random misfire. codes i got from the test was 101F01 (Not Plausible),119202 Fuel low pressure,Electrical: Short Circuit to Earth,11A210 Low pressure fuel system,Plausibility power of fuel pump is to high for actual pressure..
06-22-2020, 04:05 AM | #35 |
Rep 8
Thanks,Well i got the code 119202 and 11A210 so i made the call to do the replacement of the the LPFP and LPFP Sensor....If i run the engine and pull the coil i get response on all cylinders so i know i have spark..that made me think its fuel related.
06-22-2020, 06:22 AM | #37 | |
Rep 1,261
06-22-2020, 08:04 AM | #38 |
Rep 8
Lets hope we get some answers soon as i am all out of plans..Sending the car in 2 morrow will let you all know what was up with my F10 N55 535..if you have more info to consider please let me know...
06-22-2020, 08:14 AM | #39 | |
Rep 1,261
I mean for you, the only logical things left are the HPFP or injectors. You would think if it was injectors, we would see a related code for it. But for the HPFP, people say there is sometimes no fault for that and this may be early signs. Logs would be able to better determine that. |
