06-15-2012, 08:34 AM | #3433 | |
Rep 7,389
I find my ETs easier to use with my longer lenses. On my 500mm, cutting the minimum focus distance from 12-ft to 8-ft is huge and then I add my TC, which has no impact on MFD, and I've got a bee filling the viewfinder at 8-ft. I use it a lot with my 70-200mm also. I'm shooting at around f/8 when all that stuff is piled on an f/4 lens. I saw some amazing macros taken with a 65mm macro lens, two ET and flash. The guy specialized in macros and had a complex lighting scheme, but the results were stunning. I've got both ETs and diopetor lenses and like them both. ETs are a cheap solution on dslr, but perhaps not so much for MF. Dave
06-15-2012, 08:44 AM | #3434 |
Rep 6,798
Got a link, Dave?
06-15-2012, 09:01 AM | #3435 |
Rep 7,389
This isn't the guy I was thinking of, but this guy gets equally amazing results using a reversed enlarger lens:
http://www.flickr.com/photos/jingles...7623492127788/ I'll try to find the guy using Canon's 65mm macro lens, combined with ETs and a special lighting setup. Dave
06-15-2012, 12:17 PM | #3436 | |
183
Rep 2,391
sounds like a lot of light loss. but i don't plan on doing any macro - just closer portraits. so my set as +1, +2 and +4 diopters. the +2 diopter converts the 80mm's .8m minimum distance into a staggering .26m. the depth of field goes out the window, and with the wider frame of the 6x6 format, things get really intimate.
2009 135i | space grey | sport | navi | hifi | heated
dinan stage 2 software | bmw performance exhaust kw v2 | hotchkis front sway | vmr v710 |
06-15-2012, 12:19 PM | #3437 | |
Rep 5,114
if you put too large of an extension tube, you can actually make it so you have to actually touch the object to the lens just to get the focus point. |
06-15-2012, 12:21 PM | #3438 | |
Rep 5,114
and yes, with my longer lensees, if I use the small extension tubes, I can bring the subject slightly closer without turning the shots into macros. |
06-15-2012, 01:22 PM | #3439 |
Rep 7,389
I'm pretty sure you do. The f-stop won't change, but try a manual setting with and without the ET and notice the EV reading. I think you'll see the EV drop. It's not the optics, but the distance of the rear element from the sensor.
06-15-2012, 06:18 PM | #3440 | |
Weebl wobbles but eats Pie
95
Rep 1,794
Kevin Goto
2000 740i-Annalisa (sold 2018) 2008 335i-Weebl. Weebl may wobble but has DTC 2012 X5d in Sparkling Bronze ( The Ultimate Cat Carrying Machine)-RIP BMW buyback 2019:2017 A3, 2018 Audi SQ5 |
06-15-2012, 11:05 PM | #3441 | |
Rep 2,485
Drives: 340Xi MG 2017
Also; i should try with my 105mm.
06-17-2012, 10:00 PM | #3442 |
Rep 24,685
Drives: '04 330i ZHP
Canon guys: talk to me about AF lens microadjustments
had a buddy borrow my 16-35 and he said it was back focusing on him all week. Should I be doing microadjustments on all my lenses? How is it done? |
06-17-2012, 10:02 PM | #3443 |
Ikea enthusiast
334
Rep 8,140
Drives: '07 E92 335i
Only one of my lenses has been perfect out of the box, all others saw some benefit from MA.
06-17-2012, 11:01 PM | #3444 |
Rep 7,456
I've read some good things about Reikan Focal software. I'm thinking of trying this out myself. I have noticed a couple of my lenses seem to miss the focus point by just a bit. Maybe some MA will help.
Having said that, keep in mind that it is camera specific. A lens that front focuses on one camera may be fine on another.
06-18-2012, 12:14 AM | #3445 | |
95
Rep 1,794
This will give you an overall picture of the focusing compensation that you need. My 40D front focuses like anything with any lens on it. I cannot adjust this and would have to send it to Canon to possibly fix it. Next. and it will tell you how to MA your camera. What Mark said about the MA, it is specific to the camera and not the lens. at least this is my understanding of how it works.
Kevin Goto
06-18-2012, 07:02 AM | #3446 |
Rep 6,798
06-18-2012, 07:58 AM | #3447 |
Rep 6,798
out of curiosity, do most of you guys shoot with back button AF?
06-18-2012, 09:02 AM | #3448 | |
Rep 7,389
Dave
06-18-2012, 09:13 AM | #3449 |
Rep 1,429
edit: Wrong thread, ignore this
06-18-2012, 09:27 AM | #3450 |
Rep 7,456
Well, since he said to ignore it, I guess I will.
06-18-2012, 09:32 AM | #3451 | |
Ikea enthusiast
334
Rep 8,140
06-18-2012, 11:52 AM | #3452 | |
183
Rep 2,391
06-18-2012, 06:46 PM | #3453 | |
Rep 2,485
Personal taste I guess. I wouldnt go back to shutter-focus.
06-18-2012, 07:15 PM | #3454 | |
Rep 7,389
The AF time is the same no matter which button you push. It's really only a personal preference issue, at least with Canon's prosumer bodies. I shot around 2,000 shots last weekend with my 7D and can't remember waiting on the AF because of which button I was pushing. When I switched from a subject 12-feet away to one 50-yards away, I had to wait, but that wasn't due to the button pushed. No waiting allowed: Stay away, this is my perch! No, it's mine!!! by dcstep, on Flickr
