2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications N63 VANOS TIMING ISSUES w/ pictures
      09-09-2021, 03:09 PM   #1
Pruzina
Drives: Bmw X5M, M6, X5 5.0, 335i
Hey guys so I'm getting 130308 which indicates that there is an issue with exhaust vanos in bank one.
I did swap, clean, replace with new solenoid fault stays at the same vanos.
Ista stretch test passed.
So I'm about to pull the trigger and open bank 1 and check the timing although in ISTA timing seems to be okay.
So I'm thinking vanos gear bank 1 exhaust is probably bad.
BUT
Why if I perform one by one each vanos test using ISTA all 4 fails?
Pulling valve covers on this engine with engine in the car is no joke so I would like to hear some tips or ideas before I do so. The fault code pointing with no doubt that something is not right with exhaust bank 1 but why the hell all vanos fail?
Btw fresh oil. Drivetrain malfunction in seconds no matter the condition cold hot. Engine sounds okay no rattling noise no misfire.
      12-24-2023, 06:02 PM   #2
kelvin12382003
Hong Kong
Drives: E66 750LI
Have you solved this ?
      12-24-2023, 06:10 PM   #3
Pruzina
It's been some time. But i believe it was jumped timing
      12-24-2023, 06:11 PM   #4
Pruzina
And I think I replaced one vanos gear
