2010 2011 BMW 5 Series Forum F10 Anyone Help Me Code/Clearing error code With E-Sys? |
04-19-2016, 05:04 PM | #1 |
Rep 743
My e-sys cable is coming soon and my main focus initially is to try and clear the error code I accidentally threw when changing an interior bulb.
Can anyone point me in the right direction or offer any remote coding to do it for me? I've got a 2013 F10 (520D) and i'm in the UK. Thanks! Mark Last edited by Googlyamnesiac; 04-21-2016 at 05:24 AM.. |
04-21-2016, 05:45 AM | #3 |
Rep 8,364
You use the external transmitter in E-sys to clear some codes, but not sure whether that applies to light bulb errors.
Did you change the type of bulb? |
04-21-2016, 05:52 AM | #4 |
Rep 743
yeah the bulb is fine - it's moaning about passenger airbag - found a thread on here that explained it was a blown fuse, which I replaced. Some say the warning goes away, others say it sticks and needs to be cleared. I just want to clear mine but not sure what tool I use with my e-sys cable....?
04-21-2016, 05:56 PM | #5 |
Rep 8,364
ENET cable. E-sys is a program.
The only clearing e-sys will do is through External Transmitter. Double click transmitter → Predefined Services (scroll to bottom of list & select) → Hit connect → hit send. All set For clearing errors and diagnostics, other tools include Toolset32 with INPA or Rheingold. Not sure the following applies, but after flashing ASCM, to lock airbag, you would do the following: E-Sys Transmitter: 1) Click "External Applications" in the left menu. 2) Click "External Application" 3) Double-click "Transmitter" 4) Double-click "ACSM verriegelung_schreiben" Tool32: 1) Launch C:\EDIABAS\Bin\TOOL32.EXE 2) Hit F3 3) Load C:\EDIABAS\Ecu\ACSM4.prg 4) In the "Select Job: F01" window, select steuern_verriegelung_schreiben 5) Hit F5 6) "Results" window should show "JOB_STATUS = OKAY" |
